September 16, 2026, 01:24:54 AM
| | |-+  how to change roof panel
Author Topic: how to change roof panel  (Read 9048 times)
« on: October 28, 2009, 07:46:32 AM »
I noticed that forum member Yagmur sells new roof steel panels from Turkey:
Now this is the question: how is the 131 roof fixed? Is it welded or is there just some "glue" as in hood cover structure? Is it cheaper to fix rust spots that are in the corners near windscreen or should I better buy a new one?
Thank you for your info,  Grin
« Last Edit: October 28, 2009, 03:57:51 PM by 131DHOC » Logged
« Reply #1 on: October 28, 2009, 07:57:40 AM »
it is spot welded the whole way around & it is (or knowing fiat not) also sealed between the 2 panels.
« Reply #2 on: October 28, 2009, 08:17:23 AM »
if the problem are just rust spots around windscreen, fix those. if it's rotten all the way around as i saw few times, than it's easyer to chanhe the whole panel
« Reply #3 on: October 28, 2009, 09:33:11 AM »
ok, I think I'll fix all the small spots and go on...
Thanks  Wink
