July 24, 2026, 11:30:00 AM
| | |-+  Searching for Bearing's Abarth Gearbox!
Author Topic: Searching for Bearing's Abarth Gearbox!  (Read 19118 times)
« on: November 03, 2009, 04:32:29 PM »
Hello,
i am searching for Bearing's from Fiat 131 BB 1A 1005 Abarth Gearbox.
the part's Nr:
SKF BA2B633315A
and SKF633165
Look Pic's
Thanks  Enzo Wink
« Reply #1 on: November 03, 2009, 06:40:47 PM »
dimesions?
« Reply #2 on: November 03, 2009, 06:54:02 PM »
Can you not buy these from an SKF stockist as you have the SKF numbers?
« Reply #3 on: November 03, 2009, 07:45:33 PM »
a good bearing supplier should be able to get these?
« Reply #4 on: November 04, 2009, 08:35:23 AM »
Hello,
@mirafioriman
please make you an test for me on SKF Stocklist to find this Bearing's!
@sid
give me an good address from SKF or Bearing/Supplier! My distributor can not find this Bearing's.
Enzo Wink
« Last Edit: November 04, 2009, 08:37:33 AM by Fiat 131 Abarth#2 » Logged
« Reply #5 on: November 04, 2009, 11:25:45 AM »
Enzo i contacted a local supplier today with both the numbers you gave & the 1st one is approx ?140 + vat but the second one dont make any sense according to the bearing man (wrong number) so the first bearing is avaliable anyhow, cant understand why your bloke cant get??
« Reply #6 on: November 04, 2009, 01:18:31 PM »
Thanks sid,
the 1.st one i find allso in Italy look http://www.verzolla.com/SearchResult but i need  more the second one.
I did search on www. and can not find SKF 633165 this Nr. is typed on it.
Enzo Wink
« Reply #7 on: November 05, 2009, 03:31:38 AM »
Enzo , give me not the type but the measurements,
I will try here
sportman
« Reply #8 on: November 05, 2009, 05:56:43 PM »
HELLO ENZO I CAN THELIVER THE FIRST WHEN BA2B633315A ITS THE SAME LIKES ON MY COLLOTI GEARBOX I HAVE THATS ALS SPARE.WHEN YOU HAVE INTRESSE LET ME NOW.
SPORTMAN
« Reply #9 on: November 06, 2009, 06:35:04 PM »
SPORTMAN
Thanks Sportman yes the CIMA BOX with Colotti T.209 has the same Bearing's.
i have find one in Italy and the second in Germany.
Thank's to all for help!
Enzo Wink
* 1334.pdf (16.73 KB - downloaded 861 times.)
« Reply #10 on: November 11, 2009, 07:14:52 PM »
Hello,
the part's a here tomorrow all can together.
Enzo Wink
« Reply #11 on: November 11, 2009, 10:16:42 PM »
thats great your sorted now!
