October 22, 2026, 11:05:27 AM
| | |-+  ? About drive shaft parts from Yagmur
Author Topic: ? About drive shaft parts from Yagmur  (Read 11221 times)
« on: November 08, 2009, 11:03:34 PM »
I was going to order some bits from Yagmur for centre drive shaft and axle shaft.
He has all the bits but only for their 1600cc version of 131.
 He wants me to confirm the 2.0 bits are compatible with their 1.6.
I assume the drive shaft on the 1.6 and 2.0 are the same and use same bearings seals etc.
The final drive ratio will be different for the various engines but shaft bearings and seals etc should be the same.
Does every one agree ??
« Reply #1 on: November 08, 2009, 11:07:06 PM »
I believe this is in fact the case , the lengths were different but the parts like bearings etc., should be the same
PS:  I am looking for the longer part of the shaft (rear).
« Last Edit: November 08, 2009, 11:09:03 PM by miro-1980 » Logged
Yagmur
« Reply #2 on: November 09, 2009, 06:29:40 AM »
Hi Miro,
Thanks for the info.
Yagmur
« Reply #3 on: November 09, 2009, 09:59:34 AM »
you can see my prices at my section
« Reply #4 on: November 09, 2009, 04:15:53 PM »
Thanks for info and pictures Miro
