September 12, 2026, 09:16:44 PM
| | |-+  Rear axle 12/43
Author Topic: Rear axle 12/43  (Read 8187 times)
« on: December 03, 2009, 03:58:34 PM »
Anybody after a 12/43 axle for 131 saloon ?  its the automatic one so gearing will bottom out at 102mph on speedo if you fit it to a manual so no good for 1600 T/C  or 2000 T/C but ok for pushrod manual as 102mph limit wont be a problem, its from a mk3 131 so its the WIDER axle but not a problem as they all interfit
« Last Edit: December 03, 2009, 05:16:08 PM by david » Logged
« Reply #1 on: December 03, 2009, 06:35:02 PM »
Hi David if its wider that the sport one can you tell me how wide it is please? this is just to reference with the toyota one i have for my sport which is 24mm wider than a sport axle, thanks Nick.
« Reply #2 on: December 03, 2009, 06:47:48 PM »
I will measure it for you Nick but give me a couple of days, all the mk3 131s I have had had this wider axle, I found this out years ago as I hadnt noticed before but I removed a halfshaft from a spare axle and went to change it because the one I had had a noisy bearing and it wouldnt fit ! and when I checked the noisy bearing one I had removed was shorter, also the splines on mk3 halfshaft are different (larger)
« Last Edit: December 03, 2009, 09:34:42 PM by david » Logged
« Reply #3 on: December 04, 2009, 01:57:38 PM »
Nick, the measurement of the axles is:  mk2 131 as sport without halfshafts, backplates etc 1230mm and the mk3 131 axle 1245mm so its 15mm wider in total so 7.5mm per side which makes you wonder why they bothered re casting for 15mm !  The width of the mk3 131 axle with everything in, ie backplates, halfshafts etc is 1420mm, Now I have run both of these axles in sports but prefer the original type, also mk3 131s had wider track at the front......
« Reply #4 on: December 04, 2009, 04:13:49 PM »
Thats good news for me as the toyota axle is 1400 from disc face to disc face so plenty of room, thanks for taking the measurements for me David.
« Reply #5 on: December 04, 2009, 04:21:13 PM »
Nick, with the wider mk3 axle you can use 131 sport rims with 185/60 x 14 tyres but its very close but doesnt catch
« Last Edit: December 04, 2009, 04:39:01 PM by david » Logged
« Reply #6 on: December 04, 2009, 08:20:44 PM »
Hi David i will be using hopefully 7jx13 with 205 tyres & seeing as i can use either 98x4 or 114.3 x 4 pcd on the rear i have 8j revos in 114.3, i have 6j revos, 7j alleycats x13 & 6j revos x14 & 8j revos x 13,114.3, i have plenty tyres 205/60 215/50 & 235/50 tucked away also.
