September 13, 2026, 04:17:49 PM
| | |-+  Fiat 131 Racing air horn
Author Topic: Fiat 131 Racing air horn  (Read 28220 times)
MarkoH
« Reply #15 on: December 29, 2009, 06:12:41 PM »
I doubt if the washer bottle is heated to prevent freezing but I guess you use anti-freeze to counter that - How about the mozzles though - Do they freeze up..? Smiley
Yes - Here in Finland we are using antifreeze liquid for washer fluid antifreezing and getting drunk. The story tells that bums are filtering this antifreeze stuff through a wheat bread to make the poisons dissappear. Unfortunately it does not seem to work. I am a member of a local volunteer firefighters and too often we are resuscitating these poor guys.
Few weeks ago I heard another method to filter this stuff drinkable: When there is -30 degrees Celcius outside, you just trickle this liquid along a crowbar. Story tells that all the poisonous ingredients freeze to the crowbar and pure alcohol is dropping from the other end. Maybe I should try this because at the moment there is quite a hard winter outside. Then I can offer you guys a drink at 3MA10!
By the way - I can buy a citron odeur antifreeze from here. If I'll try with this, I hope that the citron flavour is still there.
And back to topic:
The nozzles are freezing but that is not a problem. Usually then the road is also icy and dirt is not flying like in wet conditions.
Marko Hannula
Mynamaki, Finland
Fiat Ritmo Abarth 130 TC -86
Ford Sierra RS Cosworth -86
« Reply #16 on: December 29, 2009, 07:51:03 PM »
Kev the Dino has 2 horns aswell the little town one and the get your slow car out of my way or you can clutch it and rev the ferrari lump to 8200 rpm which is enough to scare most folk  Shocked Shocked Shocked
