September 13, 2026, 11:32:37 PM
| | |-+  Brown Check front seat
Author Topic: Brown Check front seat  (Read 6569 times)
« on: January 01, 2010, 04:22:30 PM »
Need a front seat for the 131 cl in lovly brown check ,ill try and post a picture later , if im going to do near 600 miles in one day on 3ma .
if you,ve broken up a 131 and have one lieing in the shed or barn , a foam back on its own would do and a base ,
 a passenger seat will most likely have the best material and foam in best condition .
 Mine has ripped or diddintergrated on the edge of the back and foam must have dissentgrated   as i can feel the bar at the bottom , was going to strip the perfect passenger seat and swop over , then ill have two botched up as they never go back as factory would .
« Reply #1 on: January 01, 2010, 05:17:18 PM »
I have the foam base in good condition but it is just the foam, no fabric, you can have it free, just pay the p&p. regards David
« Reply #2 on: January 01, 2010, 05:21:24 PM »
have the back as well but it has blue trim but you can change with yours......
« Reply #3 on: January 01, 2010, 08:40:31 PM »
cheers david sounds great   pm sent
