July 27, 2026, 03:51:08 AM
| | |-+  131 Vinyl
Author Topic: 131 Vinyl  (Read 23214 times)
« on: January 14, 2010, 11:24:15 PM »
A quick general question.
In prep for my future restoration where can i get or source the vinyl material that goes down both windscreen pillars on the Sport Huh  or Racing.
« Reply #1 on: January 14, 2010, 11:56:20 PM »
They are a moulded plastic part that sits on top of the pillar & goes under the rubber, there is also a similar set up on the c pillar, id say they will be hard to find in good used condition & probably impossible to get new, you gac however get all the metal parts of the windscreen off Yagmur & paint them black.
« Reply #2 on: January 15, 2010, 02:09:53 PM »
I thought impossible might come into a reply somewhere.I was just looking ahead so if i damaged them while removing them in the future for the re spray.
« Reply #3 on: January 15, 2010, 05:37:26 PM »
i am not putting mine back on they are not in good enough condition & i think they are a water trap & will be painting the panels black instead
« Reply #4 on: January 15, 2010, 08:07:39 PM »
Yeath your probably right Sid they are a water trap
I jst dont know if it would look right with out them ? maybe getting rid of the front set but dont know if it would look right without the rear set.
« Reply #5 on: January 15, 2010, 08:58:16 PM »
You could try vinyl as in vinyl roof , i know mine had it on orgiinaly . . It was on its second vinly roof as the dealer one ( i belive they where put on to hide the bad paint jobs ) was wide enough to cover the whole roof  but later one's had two seams down  the sides
sam22
« Reply #6 on: January 15, 2010, 10:53:03 PM »
HI USJ . I PAINTED THE PILLERS IN MY CAR AND THEY TURNED OUT SPOT ON, AS FAR AS I KNOW I THINK NICK SENN THEM PAINTED, IF THE WEATHER CLEARS I WILL POST A PIC.
« Reply #7 on: January 15, 2010, 11:25:38 PM »
yes i have seen the pillars & they are spot on, those things will trap water & it will rust under them, even on my old sport when i resprayed it i left them off & painted the pillars black.
« Reply #8 on: January 15, 2010, 11:58:10 PM »
I agree they are acting as water traps so sam when you can post some pictures
Thanks.
« Reply #9 on: January 16, 2010, 12:19:41 AM »
Jasohn as Sid said its some type of plastic they used not vinyl on the originals but i did think of using vinyl as an option but i dont think it would look right.
But as said its maybe better with out any thing but a coat of black paint to save any rust problems later.
Cheers. 106
« Reply #10 on: January 16, 2010, 08:58:20 AM »
in my photo above thats how i bought my sport ayv 871t, part done and it had vinyl roof ,c pillers and on the a pillers . that was all riped of roof painted and c pillers gun metar and the a pillers just painted black
 also b piller covers, of which i had some carbonfibre one's but never fitted
« Reply #11 on: January 16, 2010, 10:14:32 AM »
Jasohn .
Vinyl fitted as standard to the roof, a, and c pillars, on your old Sport thats intresting i miss understood i thought you meant it had the vinyl just on the roof and the plastic material on the a and c pillars.
Im going to paint the pillars as other boys have done just to save greif i think once Sam gets a chance to post pics.
sam22
« Reply #12 on: January 17, 2010, 03:16:41 PM »
hi 106usj here are some pics .
sam22
« Reply #13 on: January 17, 2010, 03:18:01 PM »
few more
« Reply #14 on: January 17, 2010, 03:46:54 PM »
now there is a good looking 131 sport! seen her in the flesh & best of luck with her Seamus
