October 22, 2026, 09:12:22 PM
| | |-+  Engine numbers 132 CB.OA.O - challenge???
Author Topic: Engine numbers 132 CB.OA.O - challenge???  (Read 24271 times)
Mark
« on: April 13, 2010, 04:29:39 AM »
Helpp! Who knows???
Engine  132 CB.OA.O (Fiat 131 - 1982)
what is it?
Does anybody has any info about this miracle-mirage
A LOT of Thanks !!!
« Reply #1 on: April 13, 2010, 05:53:04 AM »
Hello Steve,
i help with pic!
RED = Block Nr.:
Yellow = identify Nr (131AR000) are 131 Abarth!
Black = serial no.
Enzo Wink
« Reply #2 on: April 13, 2010, 09:36:35 PM »
I have the same problem, i know the true engine number is above the oil filter but i only have the number cast on the block as above 132 CB 0A0. Where the number should be above the oil filter, the area is blank and has no been ground off its just blank.
So im lost but as i said in general discussion im sure its 1600 tc but out of what i dont know.
So Mark can you check the number above the oil filter on your engine  and you can answer the question for the 2 of us maybe as i have a blank space where the number should be.
« Reply #3 on: April 13, 2010, 10:16:00 PM »
106 is there no number stamped in the black box area?
Mark
« Reply #4 on: April 14, 2010, 03:32:38 AM »
Thank you a lot for your answers!!!
 I will check  the number and let know.
For me it, as well, very important  Grin
« Reply #5 on: April 14, 2010, 04:49:23 AM »
Hy i find this:
132 CB 0A0
Fiat 132  84 bore 1585ccm 72 KW /98 PS build from 1972-1975,and in 1979-1981 for Export to Korea for Kia in 1979 they build 132 in licence, it gives two measurements 84 x 71,5
and (80 x 80 1602 ccm up 1979 )
Fiat build this engine also for Spain it was into the Seat 132.
Enzo Wink
« Reply #6 on: April 14, 2010, 09:39:39 PM »
My engine number is in the black box area!
Mark
« Reply #7 on: April 16, 2010, 03:35:19 AM »
in RED box  Nr.: 132 CB.OA.O
                         433 56 34
on the body-car Nr. are  131 B1.000
                                    ver 131 A1 T
I?ve measured head valves, so they fit to engine 131 B1.000
So I?m almost sure that it?s my engine.
Does anybody has any info about engine 131 B1.000
hammerbeirne
« Reply #8 on: April 16, 2010, 09:45:25 AM »
Hello Mark 131b1000 engine is for a supermirafiori 1585cc and is 95bhp hope this helps cheers
Mark
« Reply #9 on: April 16, 2010, 11:40:43 AM »
Thanks a lot!!!
Does anybody have manual or instruction book/guide (in PDF or so)
for 131b1000 engine and Supermirafiori 1585cc
really need !!!
« Reply #10 on: April 16, 2010, 11:42:46 AM »
Hi mate,
Has your engine got the clutch fitted? 1600tc has a smaller clutch. Also if it's possible to get the timing belt off to count the number of teeth on the belt, this could be another indication.
hammerbeirne
« Reply #11 on: April 16, 2010, 04:26:55 PM »
The clutch on a 2 litre is 215 mm the 1.6 is smaller and the 1.3 is smaller again
« Reply #12 on: April 19, 2010, 10:07:08 PM »
hello verry limited internet access just now due to work so i will answer and check engine numbers when i get back on line
Mark
« Reply #13 on: April 23, 2010, 03:55:37 AM »
Here is on the HEAD - the same numbers on engine (in RED box)
Mark
« Reply #14 on: April 23, 2010, 04:00:05 AM »
and This is my 131 Supermirafiori
