September 14, 2026, 01:37:50 PM
Pages: 1 2 [3] 4 5 ... 12 Go Down Print
Author Topic: Fiat 131 Abarth Gr.4 Dashboard.  (Read 182219 times)
« Reply #30 on: January 22, 2011, 10:11:17 PM »
 :)Trading is ok. I will send you a pm.
« Reply #31 on: January 22, 2011, 10:51:42 PM »
Guys
I just noticed this thread is in "For Sale and Wanted" section.
If you do not object I will ask the admin to move this tread to garage or project section.
Enzo it actually is your call - you started it - do you agree ?
M
« Reply #32 on: January 23, 2011, 03:11:35 AM »
Just noticed that the windshield air vents are also different in mk1.
Problem is I have a kit for mk1.
If I try to work with mk 2 I will have to re manufacture the top of the dash.
Maybe going for the whole mk1 heater is a better solution after all.
« Reply #33 on: January 23, 2011, 08:51:06 AM »
Miro,
I may have a heater housing for you as well  Smiley But i have to look for it. Then you wouldn't need the dash.
« Reply #34 on: January 23, 2011, 08:59:26 AM »
Did I tell you I liked you a lot , lately ?
« Reply #35 on: January 23, 2011, 09:10:51 AM »
No, you haven't. But please do... Cheesy Cheesy Cheesy Cheesy
« Reply #36 on: January 23, 2011, 11:35:09 PM »
Mike,
I have found complete seat of front seat frames with the adjustment mechanism. Now, the adjustment mechanism is apart of the seat not the "sleigh" ( or the two pieces which are bolted down to the chassis , on which the seats slide front and back to allow distance adjustment).
 What do you actually need ?
« Reply #37 on: January 23, 2011, 11:38:30 PM »
Miro,
Thanks. I need the complete sleighs. That is, the whole parts between the seats and the mountings on the floor. It's one system. To make it possible to slide the seats from front to rear. You got 2 of them?
Mike
« Reply #38 on: January 23, 2011, 11:40:45 PM »
Mire,
I got four of them (two for driver and two for passenger...)
« Last Edit: January 23, 2011, 11:44:44 PM by miro-1980 » Logged
« Reply #39 on: January 23, 2011, 11:46:16 PM »
Miro,
Yes, that's what i need. And i want the 2 best of what you got  Wink Cheesy Cheesy Complete sleighs. Remember, i got nothing but just the seats.
Any luck on the window seals?
Mike
« Last Edit: January 23, 2011, 11:48:34 PM by mirafiori76 » Logged
« Reply #40 on: January 23, 2011, 11:55:15 PM »
Not yet ,
The window rubbers must be somewhere else  ...
M
Re sleighs : each seat has two such pieces right and left- you want two sets ( for both seats or just one ?
« Reply #41 on: January 23, 2011, 11:59:14 PM »
Ow, you got the ones from Racing. You wouldn't happen to have the ones from an L or CL or so, do you? These are complete units (sleighs and handles in 1 unit). If i had a picture i could show what i mean  Undecided
« Reply #42 on: January 24, 2011, 12:09:03 AM »
This is what I found .. I take it these are not the ones you are looking for ?
« Reply #43 on: January 24, 2011, 12:12:16 AM »
BTW , to keep n track with subject matter : gr 4 Dashboard
I just found the labels that came with the dash kit ...
Enzo please check if m Italian is on track:"
Pompe benz. = fuel pump
Int. Gener. = Huh?internal generator Huh?
Vant Acqua = coolant ventilator (for radiator fan manual override switch)
Luci Prof. =  hi beam ( for high beam indicator light)
Luci Suppl. =   supplementary lights (for driving/fog light switch/indicator light)
Luci Posiz. = position lights  (for switch and indicator light)
Frecce = turn signal (for turn signal indicatir light)
Avviam = starter ( for starter ?? = the two position switch on of , or the push button to engage the starter)
Alternat. = alternator (for indicator lamp)
Ventilaz. = ventilation (for heater /internal vent blower switch)
« Last Edit: January 24, 2011, 12:28:47 AM by miro-1980 » Logged
« Reply #44 on: January 24, 2011, 07:38:32 AM »
M
 Undecided No Miro. Racing seats have sleighs themselves. I need the ones from another model. I take it you don't have any then?
btw, Frecce means arrows  Smiley Wink
« Last Edit: January 24, 2011, 07:13:00 PM by mirafiori76 » Logged
Pages: 1 2 [3] 4 5 ... 12 Go Up Print
