September 12, 2026, 01:51:06 PM
| | |-+  1.6 cylinder head ( single cam )
Author Topic: 1.6 cylinder head ( single cam )  (Read 10494 times)
« on: June 05, 2010, 08:31:30 AM »
For sale ?35 + post. I know it looks dirty but this is a good cylinder head and ran perfect when removed. Mileage was 62 k
« Last Edit: June 05, 2010, 11:02:05 AM by david » Logged
« Reply #1 on: June 05, 2010, 02:54:22 PM »
would you sell just a camshaft?
« Reply #2 on: June 05, 2010, 03:05:02 PM »
Will do if you like djape but would still want ?30 as will have to spend time to remove it.  Regards David
« Reply #3 on: June 05, 2010, 03:42:36 PM »
i'll have to ask a friend of mine since it's for his 131 cl. i'll let you know in a day or two. where are you located, so i can see about the postage?
by the way, did you dissasemble that engine youself?
« Reply #4 on: June 05, 2010, 04:20:51 PM »
I am located in Uk England and I removed the head from the car.
« Reply #5 on: June 05, 2010, 04:37:46 PM »
i'm in Belgrade, Serbia. my rough guess is that postage could be in a region of 25e, but i would appreciate if you could check the cost of sending by ordinary mail, since courier services such as fedex, dhl and other charge way too much. weight of a camshaft is a factor in the price but my guess is that it weighs a bit short od 5kg.
what's the engine block like? is it any diferent than twincam or they just slapped on a SOHC head on it?
i'm asking you this because i have a engine just like that and i don't want to dissasemble the working engine to check out it's internals.
« Reply #6 on: June 05, 2010, 05:44:33 PM »
I have not got the car it came off anymore but I know from past 131s that the 1400 and 1600 single cam engines look exactly the same as I used to buy them up for axles for the sports when they were plentiful and throw the rest away also the Regatta 85 was a front wheel drive version of the same engine. If you get back to me and confirm your friend wants the camshaft then I will remove the camshaft and confirm post but you are probably quite near the weight.  David
