October 22, 2026, 11:05:52 AM
| | |-+  Drum's to Disc's 131
Pages: 1 2 [3] Go Down Print
Author Topic: Drum's to Disc's 131  (Read 42668 times)
« Reply #30 on: December 12, 2010, 09:20:50 PM »
Yes please post a picture when you have time !
I am sure it is the correct axle just because it was a UK spec 132 Fiat probably just said "stuff it" ! we will just stick drums on a few hundred 132 axle's to use up stock  Grin
« Reply #31 on: December 12, 2010, 11:40:23 PM »
and the poms won't know the difference  Cheesy
« Reply #32 on: December 12, 2010, 11:43:54 PM »
you can always check diff ratio. 1800 axle should be 4.1/1 while later 132 2000 axle is 3.7/1 and that one had drums as factory standard.
« Reply #33 on: December 18, 2010, 01:46:11 PM »
Pictures of the 132 axle I have are now in the for sale section Wink
« Reply #34 on: December 18, 2010, 04:44:13 PM »
looks exactly like any 132 axle would. with drums. if you unbolt backplate and counth teeth on diff, you can calculate transmission ratio and then you'll know from which 132 model it is. think that might help to sell it
« Reply #35 on: December 18, 2010, 06:15:27 PM »
Have some time off next week so may get time to have a look.
alan.acs
« Reply #36 on: December 27, 2010, 04:36:02 PM »
Don't fit a ford english axle i have done this mod and it just gives a choice of ratios and LSD,in standard form its not as strong as a fiat 131 axle (its only pressed and welded tin)
 fit an atlas as its stronger than a fiat 131 or ford english axle.
« Reply #37 on: December 27, 2010, 05:13:48 PM »
   I have video evidence that the ford Fiat hybrid axle will stand tarmac starts at 190bhp. Go to Gartrac and they will build you an axle you can trust ether way, I did and it won with constant standing starts, and is going to be used again in Little Toad, see other thread pix.
  Atlas is better than both but expensive and getting hard to find,  Toads fiat/Ford diff was all steel.  A standard English diff will blow behind 140ish Flw, it needs the slipper to work  I think its the amount of Torque that's the destroyer
           Roger.............  Grin
P.S.   You didn't just put a whole English under a 131 did you?  Lips Sealed
« Last Edit: December 27, 2010, 05:33:15 PM by TOAD » Logged
Pages: 1 2 [3] Go Up Print
