July 29, 2026, 07:50:41 AM
| | |-+  sagging inner roof
Author Topic: sagging inner roof  (Read 5550 times)
131 Lover
Fiat power No mercy !!!
« on: September 06, 2010, 07:56:00 PM »
Hi !
All my 131.s have a sagging inner roof, I dont think iam alone!what have you done to fix it?
,is it possible to get some waterbased sprayglue and make a small hole spay the inside and try to get it back on the inner roof  from the middle to the sides!
Please give me advise!!
Cheers Alf
These are my Fiats
2x 131 2-door 1600cl -81
« Reply #1 on: September 06, 2010, 08:20:06 PM »
Hi Alf,
maybe this helps
http://www.131mirafiori.com/smf/index.php?topic=3990.15
Greetings from germany
Heini
« Reply #2 on: September 07, 2010, 10:57:00 AM »
Hi !
Cheers Alf
I don't think what you are suggesting will produce acceptable results. The problem with the headlining is that the cloth is foam (sponge) backed and it is this spongy material that dries up and dissolves with age. So you need to remove the cloth from the polystyrene headlining mount/structure, clean off all remnants of the old sponge and reattach the cloth (preferably new) to the polystyrene. It is possible to reattach the old cloth after cleaning it well (I did after washing the cloth in the washing machine!) but you might as well get new cloth from Yagmur. I believe Yagmur also has new solid headliners for the 131 so you might want to go for that. See  http://www.131mirafiori.com/smf/index.php?topic=81.msg28580#msg28580 and http://www.131mirafiori.com/smf/index.php?topic=81.msg27436#msg27436 and http://www.131mirafiori.com/smf/index.php?topic=81.msg14065#msg14065
