September 14, 2026, 12:55:23 PM
| | |-+  2L twin cam capacitor
Author Topic: 2L twin cam capacitor  (Read 10029 times)
kkkango
« on: September 24, 2010, 02:18:39 PM »
I am after the 0.9 ohm capacitor off the bosch electronic ignition system or details of an equivalent that will fit so I can finally remove the 1800 dizzy and points it has been running on if my dizzy and box are ok
 been looking at electronic supplies sites and the lists just cause confusion.
« Reply #1 on: September 24, 2010, 02:45:51 PM »
Resistors are rated in ohms and capacitors are rated in farads (or microfarads, nanofards etc). Probably that's where the confusion comes from. Please explain in more detail what it is you are after.
kkkango
« Reply #2 on: September 24, 2010, 03:35:35 PM »
in the manual is shows a 0.9 ohm resistance in between the coil negative and the live feed to terminal 15 of the control unit, this is shown as a ohms resistance butis  listed as a capacitor.
thanks for the reply
« Reply #3 on: September 24, 2010, 03:47:10 PM »
The listing must be wrong. It must be a 0.9ohm ballast resistor. You must have the Bosch system then as that has a ballast resistor while the Magnetti Marelli unit does not have a ballast resistor. Any Bosch dealer should be able to provide a suitable ballast resistor although I would think just about any ballast resistor for a 12V coil should do.
kkkango
« Reply #4 on: September 24, 2010, 03:58:51 PM »
thanks for the quick answer.
curt
« Reply #5 on: September 24, 2010, 07:47:57 PM »
I think Theo's just off loading Ballast  Grin Grin Grin
Where you been Theo - Missed you as off late  Grin
Solihull West Midlands
« Reply #6 on: September 24, 2010, 09:36:43 PM »
I could say I've been keeping a low profile so as not to upset more people  Grin Wink  but in truth I've been too busy with life things. Plus my divided loyalties meant I was in Lancia mode for a while as last weekend was the Gamma Consortium AGM and Rally in Presteigne (Wales) even though I was the odd one out in the Trevi  Undecided (my Gamma is still in bits  Embarrassed )
But you are certainly right that I used far too much ballast in my posting above!  Grin
If anyone is interested in the Gamma weekend photos you can see mine at:
http://s801.photobucket.com/albums/yy292/Thotos/Gamma%20Consortium%20AGM%20weekend%202010/?albumview=slideshow
and Tony Harrison's photos at:
http://www.flickr.com/photos/tonysphotos/sets/72157624991252370
« Last Edit: September 24, 2010, 09:40:13 PM by Thotos » Logged
« Reply #7 on: September 25, 2010, 09:17:35 PM »
WHERE !! is your post and picture on the 131 general discussion ?? of 131 members with 131's
or are the mod's not intrested in the general public 131 owners anymore ??  Grin Grin
« Reply #8 on: September 25, 2010, 10:36:24 PM »
It's here http://www.131mirafiori.com/smf/index.php?topic=1564.0 in great detail  Wink There was no need to duplicate the information  Grin Grin
