June 11, 2026, 07:06:45 AM
| | |-+  Beta 1600 pistons
Author Topic: Beta 1600 pistons  (Read 12930 times)
USA131
« on: October 17, 2010, 02:54:58 AM »
Where would I go to find a set of 1585 Beta Pistons and how much would I need to pay? I'm doing a rebuild on my US version 1756 and I want to get the compression up to something respectable.
USa 131
« Reply #1 on: October 17, 2010, 06:41:09 AM »
doesn't your 1800 already have domed pistons?
USA131
« Reply #2 on: October 17, 2010, 03:13:16 PM »
No it does not. It has flat pistons with valve pockets, hence CR ~8.5:1 Sad
USA131
« Reply #3 on: October 17, 2010, 03:20:15 PM »
http://www.131mirafiori.com/smf/index.php?topic=3953.0
chris131
« Reply #4 on: October 17, 2010, 05:07:30 PM »
Hi, I have a set of 4 new domed high compression pistons. They are also oversized by 0.6mm. Actual size is 84.6mm. They are brand new in the box.
Email me if your interested
Email: chrissy962@hotmail.co.uk
« Reply #5 on: October 17, 2010, 09:20:39 PM »
Hi USA131 Do you have the specs of your engine? (HP,torque etc)
USA131
« Reply #6 on: October 18, 2010, 06:56:17 PM »
US  emission version of 1.8 ~ 80HP.
So it looks like a set of pistons are 200EURO. Other than buying from members are they hard to come by? For instance can they be had on ebay or online vendors?
USA131
« Reply #7 on: October 18, 2010, 07:44:12 PM »
they come up here and there. usually with a higher price than here. set of new pistons for 90's fiats is,  in my local fiat parts store, around 400e, and just a set of piston rings is aprox 80e.
therefore, i think that 200e is really not too much for a set of NOS pistons for a vintage car.
NOS pistons that i have for sale are european standard pistons for 1,8
btw, what the hell did they do to lower the hp so much in us spec 1765cc from european 107hp??? there must be something else along the flat top pistons
USA131
« Reply #8 on: October 18, 2010, 08:12:38 PM »
Retarded timing, low lift cams + EGR and smog pumps.
USA131
« Reply #9 on: October 18, 2010, 08:30:56 PM »
hmmmmm....
than it seems you need a full set to return it to eurospec.
that would mean decent carb and inlet manifold, exaust manifold and euro-spec cams.
anything else?
« Reply #10 on: October 18, 2010, 09:37:04 PM »
I think it was fitted with a catalitic converter and don't forget about the gasoline... It has less octanes than here in Europe...
« Last Edit: October 24, 2010, 11:13:41 PM by stathe174 » Logged
« Reply #11 on: October 24, 2010, 09:23:53 PM »
http://stores.auto-ricambi.net/-strse-10843/COMPRESSION-ENGINE-HIGH-PERFORMANCE/Detail.bok
Ramzi is a good bloke to deal with. I recently bought a clutch kit and other bits, including freight, cheaper than I can buy them locally.
