September 18, 2026, 04:42:12 AM
| | |-+  how can i remove paint from glass
Author Topic: how can i remove paint from glass  (Read 12965 times)
131tm
« on: November 11, 2010, 09:30:25 AM »
i recently bought a 131 and some glass is sprayed with paint........what should i do/use to remove it without damaging or matting the glass?
thinner is not good i was told is it true?
fuel injected suicide machine
« Reply #1 on: November 11, 2010, 11:47:28 AM »
You can use a rasor blade and scrap the paint off.  Smiley I do it every day.
« Last Edit: November 11, 2010, 11:49:54 AM by mirafiori76 » Logged
« Reply #2 on: November 11, 2010, 03:40:28 PM »
dot2 brake fluid will clean it flawlessly. just don't get it onto painted parts of the car. if the glass is removed from the car, apply brake fluid onto sprayed areas and let it work it's magic for hour or two than simply wipe off with a rag.
curt
« Reply #3 on: November 11, 2010, 07:53:01 PM »
Thinner is fine to use - just dont spill any of it on any paintwork you dont want to remove !! - IPA is good too ( Iso propyl alchohol) or even MEK if available ( Methyl Ethyl Ketone) But Mek will eat rubber ,plastic,paint etc. so be very careful - but strangely enough - it wont remove coffee stains - go figure !!
Solihull West Midlands
« Reply #4 on: November 11, 2010, 08:07:15 PM »
I personally would stick to a blade or wire wool, it makes less mess.....
« Reply #5 on: November 11, 2010, 08:07:58 PM »
SO DO I
131tm
« Reply #6 on: November 11, 2010, 09:54:51 PM »
tnx for reply........will try the brake fluid and thinner will give results later
« Reply #7 on: November 12, 2010, 10:57:52 AM »
I too would use (and have done in the past) the blade method. It's foolproof as well as spillproof.  Grin
« Reply #8 on: November 12, 2010, 11:02:48 AM »
but fingers aren't cutproof and glas is not scratchproof
« Reply #9 on: November 12, 2010, 11:19:45 AM »
True about fingers  Embarrassed  Especially arthritic ones like mine that don't seem to do exactly what I want and expect them to do  Cry  Grin But it will take a lot to scratch tempered glass with a blade I think. I would guess that usually paint on glass will be near the edge and because of bad masking when spraying so I'd be very careful using thinners as it will damage rubber parts. Brake fluid will be fine on rubber but it's so damaging to paint that I would be scared to use it.
« Reply #10 on: November 12, 2010, 06:54:04 PM »
I agree a stanley blade will remove any & all paint splashes with minimum fuss and no damage to your glass.
« Reply #11 on: November 13, 2010, 09:37:57 AM »
I use blades to remove paint every day.
