October 23, 2026, 02:58:22 PM
| | |-+  Rusted and cracked b pillar.
Author Topic: Rusted and cracked b pillar.  (Read 27976 times)
« on: December 06, 2010, 02:04:12 PM »
Hello everybody, I'm facing a problem with a rusted MkIII supermirafiori, the central pillar is totally gone, the low end part is badly rusted and cracked, so when I drive it, it sounds like there is no more link between chassis and roof on this side. Door clings and cracks, lots of noise from there. Do you know if I can just change the lower part of the pillar or need the under door panel too? This is a picture of the situation, there is a lot of concrete covering the totally rusted pillar. I think it should be welded to the reinforcement going from side to side, isn't it?
« Reply #1 on: December 06, 2010, 04:32:56 PM »
I would start by cleaning all the paint off the area to see exactly what is what.
« Reply #2 on: December 06, 2010, 04:50:23 PM »
hello, there has been rust from 15 years or so there, but the sill seems to be good, just the b pillar showing rust. You can put a screwdriver in, so the part is totally gone. Can I just buy the pillar and cut the lower part and weld as it is or will need some reinforcement welding before?
« Reply #3 on: December 06, 2010, 05:28:15 PM »
You should be able to weld in a repair section. I would tack it in place and check the door allignment carefully before seam welding in place.
« Reply #4 on: December 06, 2010, 05:32:03 PM »
anyway rear door will need to be removed before, and inner plastic parts and bits too. But, how much important is the pillar basis structuraly? Could noise come from inner steel parts failure?
« Reply #5 on: December 06, 2010, 05:42:25 PM »
It's hard to say but if you remove the damaged area you should be able to see the inner structure and inspect it.
« Reply #6 on: December 07, 2010, 03:36:03 PM »
Hello, I have inspected the rear side of this part and discoverede that it's all perfect except for the part I have marked in blue:
Do you think is possible to ask the man that will repair it to put a steel patch and weld with no need of original parts? The new pillar would remain allmost unsused except for this tiny part, so I would not buy all this not necessary stuff...... Huh
« Reply #7 on: December 07, 2010, 03:41:57 PM »
Don't you think yourself it's easier and cheaper to just weld in a small piece of metal? Therefor you don't have need of the whole pillar.
« Reply #8 on: December 07, 2010, 04:15:23 PM »
Yes but the problem is that this is a structural part and I need strenght to achieve reliability.....
« Reply #9 on: December 07, 2010, 04:58:13 PM »
Take a piece of 4 mm or 5 mm sheet metal and bend it in the right form. Cut away the rusted part en weld in the new one. It should be strong enough.
« Reply #10 on: December 07, 2010, 06:20:06 PM »
Have you tried bending 4 or 5mm sheet? Undecided
I cant remember off hand but I would guess this part originally was probably 1.2mm outer skin with a 2mm reinforcement inside.
« Reply #11 on: December 07, 2010, 06:54:03 PM »
Do you know if it's possible for a garage to remake the lower end of this part without need of original parts?
« Reply #12 on: December 07, 2010, 07:05:37 PM »
Somebody experienced in body repairs should be able to make thic piece yes. Alternatively if you can find a scrap 131 where this piece is solid you could cut it out and use it to repair yours. This is why I usually chop up my scrap shells and keep any non rusty bits for re-use Wink
curt
« Reply #13 on: December 07, 2010, 08:27:20 PM »
Personally - I would remove all the ancillary trim and take a grinder to it - I think that you will find a lot more damage than you think.
For a 'filler' repair in that area usually means there are a lot more problems !!
Sorry !! Just my opinion - strip it right back and take another photo !!
Solihull West Midlands
131 Lover
Fiat power No mercy !!!
« Reply #14 on: December 07, 2010, 09:12:29 PM »
I agree with Curt, its always more than double amount of rust than you can see in these parts of the car from experience!
You start cut in the rusted area and then put the weld to it and just blubbers,then you have to cut out more, when you are finisched you replaced the hole part anyway, with a lot more work and looking worse..
Just my opinion!
Regards Alf
These are my Fiats
2x 131 2-door 1600cl -81
