October 23, 2026, 05:39:24 PM
| | |-+  Which oil for 131 sport gearbox?
Author Topic: Which oil for 131 sport gearbox?  (Read 8893 times)
chris131
« on: February 15, 2011, 01:48:43 PM »
Hi all, I'm looking to know what type of oil should go into a 131 sport gearbox?
chris
« Reply #1 on: February 15, 2011, 02:14:14 PM »
Chris,
15W90 was what they used in the 70's and 80's.
« Reply #2 on: February 15, 2011, 02:53:42 PM »
We've discussed this in the past a few times so you might want to do a search and see what's been said.  The gist of it is that Fiat claim it should be a non-EP gear oil. Fiat's version is the Tutela ZC90 oil and it should still be available from most Fiat garages or people like Ricambio (have a look at http://www.ricambio.co.uk/index.php?route=product/product&keyword=zc90&product_id=453). Because non-EP gear oils were not widely available in the UK, Fiat UK recommended using engine oil in their gearboxes. You can use a straight 30W engine oil (a 30W engine oil has the same viscosity as a 90 gear oil) or use a multigrade engine oil like 20-40 (I would avoid the very thin 0-40 modern engine oils).  A lot of people have used 90EP gear oil in their gearboxes for years and have not had problems but why take the risk.
« Last Edit: February 15, 2011, 03:03:05 PM by Thotos » Logged
« Reply #3 on: February 15, 2011, 03:00:36 PM »
I did  Grin (a search that is) so have a look at http://www.131mirafiori.com/smf/index.php?topic=1922.msg12531#msg12531
