October 24, 2026, 10:11:23 PM
| | |-+  no spark??
Author Topic: no spark??  (Read 7281 times)
jack1
« on: February 18, 2011, 11:28:19 PM »
hi ,,1300 engine and no spark at the plugs and a great spark at the points  ,tried 2 dissy caps and 2 different sets of leads(both used) and su  the coil is good,,any ideas??
1996  850r (sleeper)
« Reply #1 on: February 18, 2011, 11:31:30 PM »
Condensor failure?
« Reply #2 on: February 18, 2011, 11:37:40 PM »
If you have spark at the points and no sparks at the other end (plugs ) the failure must be somewhere in between.
Condenser is the most likely suspect, if the condenser is OK the rest of the way is :
Not much other possibilities left : rotor - possible but not very likely, cap (not very likely),  cables (very unlikely).
If you change the condenser the spark should come back!
