October 25, 2026, 01:01:02 AM
| | |-+  no fuel being pumped
Author Topic: no fuel being pumped  (Read 31601 times)
jack1
« Reply #15 on: March 17, 2011, 09:07:55 PM »
Try to suck some fuel to the front from the reservoir and then try throw some directly in the carb. This should make the pump going Wink
working after a good suck Wink
1996  850r (sleeper)
jack1
« Reply #16 on: March 23, 2011, 11:07:04 PM »
hi all  ,,,, ok   he  now  has  fuel  to  the  carb  and  he  has spark  and  the  timing  is  set  up  but  he  car  wont  fire?HuhHuhHuh?   anyone
1996  850r (sleeper)
« Reply #17 on: March 23, 2011, 11:13:30 PM »
The fuel can not be getting to the cylinders. Is there fuel in the float chamber?
jack1
« Reply #18 on: March 23, 2011, 11:47:02 PM »
i know the plugs seem like there getting no fuel dave and dont smell of fuel  after continuous turning over???  float chamber??
1996  850r (sleeper)
« Reply #19 on: March 23, 2011, 11:52:02 PM »
Has the car not been used for a while? Perhaps the needle valve in the carb is stuck shut?
jack1
« Reply #20 on: March 24, 2011, 12:06:11 AM »
needle valve??
1996  850r (sleeper)
« Reply #21 on: March 24, 2011, 12:10:24 AM »
Need to know what carb it is really but on most you remove the top cover, the chamber should contain fuel.
jack1
« Reply #22 on: March 24, 2011, 12:18:01 AM »
hmmm,, its a weber carb  flap on top worked by choke and a flap down at the bottom ,,when you pump the accelerator by hand it lets the fuel into the carb
1996  850r (sleeper)
« Reply #23 on: March 24, 2011, 03:32:40 AM »
If your accelerator pump is delivering fuel you've got fuel in the float bowl. If it won't fire when turning over and pumping the accelerator, it's either flooded, (plenty of fuel) or you've got a spark/timing problem. In which case it should still cough and fart if the timing's anywhere near where it should be.
« Reply #24 on: March 24, 2011, 11:10:02 AM »
It's rather common it seems to get the timing 180 degrees out (I certainly fell for that one  Embarrassed). With the timing marks aligned it is number 4 cylinder at TDC and ready to fire and not number 1 as most assume. So double check the ignition timing by setting up the camshaft/crankshaft marks and removing the distributor cap to verify that the rotor arm is pointing at number 4 cylinder position.
jack1
« Reply #25 on: March 24, 2011, 10:23:59 PM »
yes dave there was fuel in the float chamber
1996  850r (sleeper)
jack1
« Reply #26 on: March 24, 2011, 10:29:06 PM »
[/quote
plugs are bone dry(if flooded wouldnt they be wet?) got spark at the plugs  ,,, have checked the timing and everything seems to line up spot on?HuhHuh
1996  850r (sleeper)
jack1
« Reply #27 on: March 24, 2011, 10:33:45 PM »
[/quote
firing order is 1,3,4 and 2   ,,,,,,,  isnt  (2 )  actually cylinder 4  so rotor arm should point at the third cap on the dissy ?? does this make sense
1996  850r (sleeper)
« Reply #28 on: March 25, 2011, 12:35:01 AM »
[/quote
With the crank at TDC and the cam pointers lined up, whichever pin the rotor button is pointing at should have the lead from number 4 cylinder on it!
« Reply #29 on: March 25, 2011, 10:43:39 AM »
Yes and number 4 cylinder is the one nearest the bulkhead.
