September 13, 2026, 01:56:57 PM
| | |-+  131 ohv water pump
Author Topic: 131 ohv water pump  (Read 6134 times)
fi131
« on: April 04, 2011, 09:34:15 PM »
Last weekend i decided to change the water pump in my 131 ohv engine Browsing some on-line catalogues from different aftermarket water pump suppliers ( graf ,saleri, buggati ) i noticed that the water pump for 131 ohv engines is different from what i already had in my 131 ohv engine.
The water pump in my block  looks like the one that is supplied for the earlier 124 ohv type engines .
As it appears in the attached photos although both 124 ohv water pumps and 131 ohv look identical ,there is a difference .
Water pump in my engine 124 type probably ?
There is a different bulge in the upper  left side of the 131 pump (spotted with a red arrow in the photos )  and  a slightly wider water port in the opposite side as well .
Both water pumps are for ohv engines not twin cam ones but...
Are both the 124 ohv and 131 ohv w/pumps  interchangeable or the one provides better water circulation than the other ?
Is it wrong that my 131 ohv engine  is installed with this type or there is no problem
« Last Edit: April 04, 2011, 09:36:43 PM by fi131 » Logged
