October 18, 2026, 08:51:32 PM
| | |-+  Question...... Your help please....
Author Topic: Question...... Your help please....  (Read 10232 times)
greek mirafiori
« on: May 10, 2011, 02:21:42 PM »
I have a liitle trouble with my 131.... I have to replace the part you are going to see in my photos...... It is attached in the front of the engine and transports the water from the thermostat and the radiator to the engine. Does anyone know its name in english? Do you know where can I find? I have already asked Yagmur and I am waiting for his answer...
Thank you guys in advance.
P. Katsivas-Fiat 131 Mirafiori CL, 1.6 ,Fiat Grande Punto 1.4 95 hp 'Racing' owner
Kalamata, Hellas.
greek mirafiori
« Reply #1 on: May 10, 2011, 02:23:33 PM »
Look and this
Kalamata, Hellas.
Yagmur
« Reply #2 on: May 10, 2011, 04:18:15 PM »
I have,don't worry.
« Reply #3 on: May 10, 2011, 05:38:23 PM »
You want to use some antifreeze in your engine (50/50 mix) as it has corrosion inhibitors and stops the parts corroding like this. its not just to prevent the engine freezing up.
greek mirafiori
« Reply #4 on: May 10, 2011, 08:57:37 PM »
I use only anti freeze and I can't understand how this happened. Maybe because of the long stay in the car.....
Kalamata, Hellas.
« Reply #5 on: May 10, 2011, 09:17:04 PM »
But you do mix the antifreeze with water?
« Reply #6 on: May 11, 2011, 03:08:12 AM »
Give the block and radiator a good flush before you put it all back together. Use a good quality coolant/antifreeze/corrosion inhibitor, in theory they should be replaced every 12 months, although some manufacturers say 24 months.
greek mirafiori
« Reply #7 on: May 11, 2011, 08:52:18 AM »
Ok thank you Tas for your advice...... I'm going to do it.
Kalamata, Hellas.
« Reply #8 on: May 11, 2011, 02:26:30 PM »
I don't understand as I have left a 131 in a garage with 50/50 mix of antifreeze in a garage for six years and the cooling system was clean as it could possibly be ( virtually as new ).
The only time I have seen anything like this is when cars have been run on just water for years.
« Reply #9 on: May 12, 2011, 04:47:42 AM »
Agreed, if the coolant's green the system is usually pretty clean. I don't change mine unless I have cause to drain the system, the 12 months is a product manufacturers ideal. Distilled or de-ionised water is also recommended, so mixing 50/50 coolant and sea water I reckon you'd still get corrosion. Grin
« Reply #10 on: May 12, 2011, 11:13:47 PM »
use only paraflu or G12 pink antyfreeze 50/50 mix
there's cheap green antyfreeze out there that just eats aluminium
