September 17, 2026, 10:22:58 AM
| | |-+  strada 130 engine
Author Topic: strada 130 engine  (Read 13562 times)
gerafiori
« on: October 04, 2007, 08:14:22 PM »
has anyone ever put a 130 abarth engine from a strada into a 131 sport,
i have sourced an engine as above with 175 brake {high comp pistons +
highlift cams} should make my 131 move a bit quicker.
gerry...............
barry
« Reply #1 on: October 05, 2007, 01:31:11 PM »
Hi Gerry there is a very good thread on Guy Crofts forum also i think Steve who lives in spain has done the exact thing, there seems to be a slight modification of the gearbox shaft ie grind a few mill  and round off the end plus a bearing is needed to support the shaft, i am in the process of putting a 8v integrale engine in and its the same for that. regards barry
« Reply #2 on: October 12, 2007, 04:37:48 PM »
You can leave the sump on as well as the oil filter housing.
http://www.guy-croft.com/viewtopic.php?t=720
I also have a spare bearing as i ordered two just incase.
« Last Edit: October 12, 2007, 04:39:24 PM by parrish » Logged
gerafiori
« Reply #3 on: October 14, 2007, 08:21:12 PM »
thanks guys,
guy croft site has a wealth of info,
regds gerry.....
martyk
« Reply #4 on: October 26, 2007, 11:42:14 PM »
hi ger why not put your porshe engine into it  i knew your were going to put something with a bit of va va voooooooooom Grin
Tristan
« Reply #5 on: October 27, 2007, 09:56:32 PM »
You can call out to ours if ya like Gerry , We've a gearbox out on the ground , and an 8v 2.0 if you want to see any of the measurements.
gerafiori
« Reply #6 on: October 28, 2007, 12:48:06 PM »
hi ger why not put your porshe engine into it? i knew your were going to put something with a bit of va va voooooooooom Grin
i dont think 911 would pull great with 2ltr twin in the back
gerafiori
« Reply #7 on: October 28, 2007, 12:51:27 PM »
 what hsepower in that engine that you have?
Tristan
« Reply #8 on: October 28, 2007, 01:47:40 PM »
fast road cams , twin dellortos , ported and polished without biggish valves , I'd say about 135-140 bhp.
« Reply #9 on: October 29, 2007, 01:25:36 PM »
are they horizontal or vertical carbs on that engine  Smiley
Tristan
« Reply #10 on: October 29, 2007, 07:39:32 PM »
Sidedraught , not like the Abarth .
martyk
« Reply #11 on: October 29, 2007, 10:29:40 PM »
 tristan i would say that gerry would be looking for something with about 300 horses galloping underneath it  Grin Grin why not put the 130 engine into the x19 put a bit of weight in the front and stiffen up the suspension  Huh Huh
