September 14, 2026, 05:31:52 PM
| | |-+  Converting to electronic ignition.
Author Topic: Converting to electronic ignition.  (Read 14456 times)
« on: September 01, 2011, 11:11:23 AM »
Does anyone know if it is possible to convert a 1585cc OHV engine to electronic ignition by fitting the distributor from a 2 litre?
« Reply #1 on: September 01, 2011, 11:37:50 AM »
As a guess I'd say 'yes' but you need to fit the complete distributor as well as coil with electronics module from a 2 litre. If you are going to use the Bosch system then the ballast resistor for the coil also needs to be fitted. But as I said, this is just an (un)educated guess and not something I've done before.
strada
« Reply #2 on: September 03, 2011, 09:18:44 PM »
if it doesn't work, i have money waiting for a s3 2litre electronic distributor
« Reply #3 on: September 03, 2011, 09:25:12 PM »
It's someone I sold a 1600 OHV engine to. He wants to convert it to electronic ignition.
« Reply #4 on: September 04, 2011, 10:28:00 AM »
Yes you can I've done it using the 131 2.0ltr Marelli system, the wiring will all match up as well. The Bosch system is far more complicated.
         Roger...........
« Reply #5 on: September 04, 2011, 09:16:16 PM »
Thanks I will pass the message on Wink
Dave
selem
« Reply #6 on: September 08, 2011, 10:20:58 AM »
yup, just plug and play...
fiat 131S
jseabolt
« Reply #7 on: September 30, 2011, 05:03:15 AM »
If you can verify if a 124 cam mounted distributor uses the same points as your engine why not go with a Pertronic Ignitor:
http://stores.auto-ricambi.net/-strse-10506/ELECTRONIC-IGNITION-CONVERSION-PERTRONIX/Detail.bok
I'm been running one on my 68 Ford Fairlane for 10 years and it's worked fine.
1981 Trabant 601
2003 Subaru Baja
finnie
« Reply #8 on: October 25, 2011, 10:25:45 PM »
Just had my 1.6 TC converted for ?50 by Ignitionland from ebay. incl new coil  Wink
« Reply #9 on: October 25, 2011, 10:50:57 PM »
That sounds like a good deal. Did they fit an electronic ignition system to your existing points distributor?
finnie
« Reply #10 on: October 26, 2011, 06:03:46 PM »
Yep  Wink
