September 15, 2026, 04:38:39 AM
| | |-+  Searching Electric Connectors
Author Topic: Searching Electric Connectors  (Read 7173 times)
rosi
131 Rally
« on: December 02, 2011, 10:14:46 AM »
Search electric connectors from 131 mirafiori first series.
Anybody can help me?
Look following topic:
http://www.131mirafiori.com/smf/index.php?topic=5235.0
« Reply #1 on: December 02, 2011, 03:18:24 PM »
i think it's not so easy to find this connectors form serie one 131!
but i can make an picture from my solution (131 Abarth).
if you interest?
Saluti Enzo  Wink
« Reply #2 on: December 02, 2011, 04:25:08 PM »
It's a long time since I've had or even closely looked at a Series 1 but from memory they used open contact wire to pcb molex type connectors (www.molex.com). If someone can post a picture of the required connectors I might be able to find a source for them. Alternatively, solder the wires straight onto the pcb in the lights and that way you won't get the usual bad connections to the lights  Wink If you need to have a quick means of removing the lights then fit an in-line multiplug connector in the wires close to the lights.
rosi
131 Rally
« Reply #3 on: December 02, 2011, 05:46:46 PM »
hello all
many thanks for your answer and information.
please send me pictures of your solution.
many thx
rosi
« Reply #4 on: December 02, 2011, 06:39:25 PM »
i was now into the workshop to make some pictures!
i hope you can see what i've done, i have soldering the cable into the hollow rivet from the light fixture mounting.
Saluti Enzo  Wink
rosi
131 Rally
« Reply #5 on: December 02, 2011, 06:46:43 PM »
Grazie mille Enzo!!
I will soldered the cable same as your picture.
regards
rosi
