September 13, 2026, 04:42:00 PM
| | |-+  Fiat 131 Lubricants
Author Topic: Fiat 131 Lubricants  (Read 17735 times)
« on: July 19, 2012, 06:14:08 PM »
I need to get some oils for the new 131 and I did some research on here and in a Haynes manual.
For the diff, Haynes reccomends SAE 90EP although I recall a debate where EP was advised against. What brand/grade do people normally buy?
For the manual gearbox, Haynes says Oliofiat ZC90 or 80W/90 oil. Again what do people normally buy?
And Dot 3 for brake fluid?
« Reply #1 on: July 19, 2012, 06:39:15 PM »
Engine oil Castrol GTX 15/40
I used the same in the gearbox Smiley
For the diff EP90. It's the gearbox you shouldn't use EP in.
As for the brake fluid I used DOT 5.1. DOT 3 or 4 should be fine. I would change it totally to be safe.
« Reply #2 on: July 19, 2012, 06:44:12 PM »
Millers make very good gear oils Smiley
http://www.ebay.co.uk/sch/i.html?_odkw=millers+diesel&_osacat=0&_trksid=p2045573.m570.l1313&_nkw=millers+80W%2F90+&_sacat=0
You will find most motor factors have Dot 4 this has replaced Dot 3.
« Reply #3 on: July 30, 2012, 12:10:00 AM »
Kevin,
The fact is that all modern oils are very good, but when you push your engine this is when you need the best.
I use of Motul  all around : bake fluid (dot 5.1), engine oil, gear box oil, diff oil). Only for coolant I use original Fiat Paraflu
For gear box and non LSD diff I use the one with molybdenum additive - it stinks bad but this is the best there is. For Engine I use 300V competition 15-w50 synthetic. Magnificent. Brake fluid is 5.1 ( with the highest temperature resistance in industry).
Note that Motul is a small operation as compared to its Big brand name competitors. The difference is they really make their own instead of subcontracting all kinds of  refineries all around the world which just add additives to their own base oil-  and here comes out a Castrol, Elf or Mobil.
As they say "never drink a whisky from a distillery that makes zillion of bottles"
Such volume is always for everyone. This means for average user and average use.
Very good , but not for extreme conditions and extreme use.
So ultimately the choice of oil is defined by the use. If you use it like most average users any oil is fine.
If you run your engine frequently over 8K RPM at high temperatures, brake very hard , shift quickly and always ether accelerate full throttle and brake at full force the average will not be enough.
« Last Edit: July 30, 2012, 12:29:01 AM by miro-1980 » Logged
Michohat
« Reply #4 on: July 30, 2012, 01:01:51 PM »
i am from egypt and own fiat 131 1979 1600 cc tc
i use for
engine oil : liqui moly Formula Super 20 W-50 + Cera Tec
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_1444.html?Opendocument&land=GB&voilalang=e&voiladb=web.nsf
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_3721.html?Opendocument&land=GB&voilalang=e&voiladb=web.nsf
gear oil : mobil 1 90
rear axle oil  : mobil 1 90
break oil : liqui moly dot 3
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_3090.html?Opendocument&land=GB&voilalang=e&voiladb=web.nsf
Fiat 131 SuperMirafiori 1979  1600cc Twin Cam
EGYPT
« Reply #5 on: August 13, 2012, 07:04:33 PM »
dot 5.1 is sytetic . and should only be used when w hole system is new, stick with dot 4 mineral
« Reply #6 on: August 13, 2012, 07:18:04 PM »
Dot 5.1 is compatable with previous mineral fluids such as DOT 3 and DOT4.
However as said earlier I would change it completely. Brake fluid should be changed every two years as part of the service schedule.
Unfortunately it seldom is and if you buy a secondhand car it's likely to have very old fluid in it Roll Eyes
« Reply #7 on: August 16, 2014, 09:32:26 AM »
Dot 5  =  synthetic   Requires complete flush and change
Dot 5.1 = is normal fluid    Just bleed through to replace.
