September 13, 2026, 05:35:17 PM
| | |-+  engine oil cooler kit any info.
Author Topic: engine oil cooler kit any info.  (Read 11543 times)
Michohat
« on: August 26, 2012, 11:36:29 AM »
hi there
i find this part on internet and want to ask is is usefull for me here in egypt its to hot and
http://www.ebay.co.uk/itm/FIAT-TWIN-CAM-124-125-132-131-TC-ENGINE-OIL-COOLER-KIT-/150879820127?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item232123595f
http://www.vickauto.com/newstore/index.php?main_page=product_info&cPath=5_6_24&products_id=3564&zenid=93ecea5a11bae637be5c2b719e8634c8
http://www.jcwhitney.com/oil-coolers/fiat-131/c7258d572j1s21.jcwx
Fiat 131 SuperMirafiori 1979  1600cc Twin Cam
EGYPT
« Reply #1 on: August 27, 2012, 12:44:52 PM »
An oil cooler kit is very useful at keeping the oil cool so it maintains its viscosity. It's a 'must' for an engine that is used very hard for example in racing or towing etc. But while it will help at keeping an engine cooler in a very hot climate, its effect will be very little in a 42 degree traffic jam in Cairo. I think you'd be better off spending your money on a new three-core radiator and possibly a larger Kenlow fan. Also make sure your water thermostat opens and closes at the correct temperature and your fan switch on the radiator works correctly; if in doubt replace it when replacing the radiator.
Michohat
« Reply #2 on: August 28, 2012, 08:32:53 PM »
i am already using Copper radiator  with 3 Pipes with the origenal fan and another fan on the water pump runs always
i didnt fing a good  water thermostate here cause it hang alot so i canceled the hot water line cause the motor take 2 :3 min to worm up
EGYPT
Michohat
« Reply #3 on: August 30, 2012, 09:14:52 AM »
that what i did to cancel the water thermostate
its from another site
EGYPT
« Reply #4 on: August 30, 2012, 10:02:46 AM »
I'm not sure on the Fiat twin cam but on some engines removing the thermostat can cause overheating problems. Removing it doesn't always increase the cooling effect.
« Reply #5 on: August 30, 2012, 10:20:09 AM »
How about using an electric water pump like the link below, that way the pump can turn as fast as it needs to even when the car is in traffic.  Wink   expensive but should do the trick.
       Roger.........
Davies Craig water pump AND CONTROLLER.
   http://www.daviescraig.com.au/Electric_Water_Pumps-EWP115_Alloy___Controller_Combo__12V____PART_No_8050-details.aspx
P.S  I forgot,  have the radiator re-made with a thicker core, that works as well.
« Last Edit: August 30, 2012, 10:29:18 AM by TOAD » Logged
Michohat
« Reply #6 on: August 30, 2012, 02:52:28 PM »
i think all fiat here in egypt canceled that water thermostat not radiator thermostat cause the water thermostat after awhile will not work ( bad type )and will re enter the hot water in engine again
EGYPT
Michohat
« Reply #7 on: August 30, 2012, 02:56:01 PM »
       Roger.........
i think its good one but i think i can not find it in egypt i will search and see if can find something i can use even with manaul button
EGYPT
