October 24, 2026, 04:10:59 PM
| | |-+  Gearbox Mount for Series 3
Author Topic: Gearbox Mount for Series 3  (Read 24386 times)
« on: September 13, 2012, 08:31:46 PM »
The attached shows a series 1 and 2 gearbox mount - support.....I believe.
http://www.ebay.it/itm/SUPPORTO-TASSELLO-SOSTEGNO-MOTORE-LATO-CAMBIO-FIAT-131-S-L-CL-SUPERMIRAFIORI-/220866598980?pt=Ricambi_automobili&hash=item336cacd844#ht_1426wt_922
I understand that the series 3 is different. Does anybody have a picture of one..or even better know where one can be sourced please?
« Last Edit: October 05, 2012, 07:38:36 AM by kev131 » Logged
Yagmur
« Reply #1 on: September 13, 2012, 09:13:05 PM »
I sent you the correct one..
« Reply #2 on: September 13, 2012, 09:15:34 PM »
I think I have one somewhere. If I can find it tomorrow I'll post up a picture of it.
« Reply #3 on: September 14, 2012, 12:38:59 AM »
Thanks both.... Smiley
« Reply #4 on: September 22, 2012, 09:01:32 PM »
These are some pictures of a very worn series 3 gearbox mount....
« Reply #5 on: September 22, 2012, 09:08:09 PM »
Yes that's what I was thinking of. I drilled a hole in each end and bolted mine back together Wink
« Reply #6 on: September 23, 2012, 08:15:23 AM »
bit of  glue thats all it needs to rebond the rubber  Cheesy Cheesy Cheesy
« Reply #7 on: October 05, 2012, 07:38:12 AM »
Still looking for this - The series 3 is very different from earlier versions....
Any ideas anyone....? Smiley
« Reply #8 on: October 05, 2012, 08:08:41 AM »
Why don't you revert back to the old version? Series 3 seems to have softer mounts.
« Reply #9 on: October 05, 2012, 04:40:56 PM »
Do you know if they are compatible Bobby?
The mounting parts are very different designs !  Huh
« Reply #10 on: October 06, 2012, 01:17:32 PM »
You can interchange the whole unit but you will need the metal bracket for the relavent one as they don't intechange but to be honest the series 2 one was far superior as the later one was a very bouncy, wobbly affair.
« Reply #11 on: October 06, 2012, 02:18:29 PM »
Not had a chance to check but bracket must be different.
« Reply #12 on: October 28, 2012, 08:09:30 PM »
Bump - Still looking for a new one...apparently it's unique to the series 3.
Thanks in advance....
« Reply #13 on: October 29, 2012, 06:14:46 PM »
Heres another picture of series 2 one including sport from different angle
« Reply #14 on: October 29, 2012, 06:56:11 PM »
Hi David - I have this type from series 2 - The series 3 is different again.... Huh
