September 13, 2026, 05:25:04 PM
| | |-+  clearance valves 131 16v
Author Topic: clearance valves 131 16v  (Read 15335 times)
joan131
A happy men
« on: September 23, 2012, 10:47:33 AM »
Hello, my engine 16v is died,the timing belt broke (2 bent valves)
 Anyone know the valve clearance on these engines? Thank you.
« Reply #1 on: September 23, 2012, 11:17:39 AM »
What engine do you have? Original 131 16V? What's the set-up? Standard 140 bHp?
joan131
A happy men
« Reply #2 on: September 23, 2012, 03:02:46 PM »
Original 16v.Camshaft: Lift 13,0 mm, interverence 5,5mm with spraed angle 105 rad,new bore size, forged pistons, larger diameter valves, 36.5 and 31,5mm, weber carburetors feed 44idf, 180hp-200hp power estimated.
« Reply #3 on: September 23, 2012, 03:07:21 PM »
I guess standard clearence isn't suitable in your case. Engine is modified, it seems. Never checked clearance before? What do the other valve clearances say? The ones that are not broken, i mean.
« Last Edit: September 23, 2012, 03:17:01 PM by mirafiori76 » Logged
joan131
A happy men
« Reply #4 on: September 23, 2012, 04:14:30 PM »
In other valves the setting changes, varies between 0'40max to 25min intake, in the exhaust varies 50max 30 min
131rally
« Reply #5 on: September 23, 2012, 06:25:53 PM »
I have the factory manual for 131 Abart Stradale. I will check when Im at home.
« Reply #6 on: September 23, 2012, 08:17:00 PM »
I have the same manual here. I also have the clearences for my 230 bHp engine. But i don't think both are very helpfull for an engine that's slightly tuned. 180-200 bHp is right in the middle of the specs i have here  Embarrassed
131rally
« Reply #7 on: September 23, 2012, 08:24:16 PM »
What are the clearances for them?
Marko
« Reply #8 on: September 23, 2012, 08:35:51 PM »
I don't have them nearby right now, but i will have them soon.
« Reply #9 on: September 23, 2012, 08:47:53 PM »
But is it of interest if i put some specs here from a 230 bHp engine?
131rally
« Reply #10 on: September 23, 2012, 09:16:11 PM »
Interesting to hear what is the difference between them. I think the g.4 clearances isnt too far for the use for the fellow who asks them. Ofcourse profile of the cam and springs used will do difference, but still, close enough propably.
« Reply #11 on: September 23, 2012, 09:19:01 PM »
You could have a point here. But then i will put those specifications in my own topic. I think they belong since i am the only 131 Abarth gr. 4 car owner here  Smiley
joan131
A happy men
« Reply #12 on: September 23, 2012, 09:42:11 PM »
If you can put the Valve clearance you have in your handbook, you would have an idea as mine, thanks
« Reply #13 on: September 23, 2012, 09:55:45 PM »
I will get them asap for you. I'd really have to search for my manual.
joan131
A happy men
« Reply #14 on: October 01, 2012, 07:03:36 PM »
Hi, finally got the Valve clearance of my engine.0,20 in,0,25 ex.
 I wonder if ever mirafiori76 has dismantled its gr4 engine.
 Does your motor these parts in the cylinder head? Hole spacing I think the interior is  very small and does not leave grease well camshafts.
