September 14, 2026, 07:14:56 PM
| | |-+  Capacitor/Module
Author Topic: Capacitor/Module  (Read 10532 times)
« on: October 10, 2012, 07:41:28 PM »
I need to find one of these for my Super...but I'm not sure exactly what it is called or from where I can find one.....any thoughts please? It's branded Magneti Marelli. Thanks.
« Last Edit: October 10, 2012, 08:12:16 PM by kev131 » Logged
« Reply #1 on: October 10, 2012, 07:48:27 PM »
That's not a capacitor. It's the electronic ignition module. Are you sure it's gone wrong? Car wouldn't work at all if that's gone wrong. They don't often go wrong but the wire that goes from there to the distributor always go wrong.
« Reply #2 on: October 10, 2012, 07:59:10 PM »
Thanks Theo - Is the wire being referred to called the Ignition Pick up lead ? If yes, that has been replaced.
The car is running - It's just a reccomended replacement by the garage while the car is undergoing other preventative maintenance work.  Smiley
Maybe this is it....although there are lots of options. I'll drop them a line...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290623518155
« Last Edit: October 10, 2012, 08:28:30 PM by kev131 » Logged
« Reply #3 on: October 10, 2012, 08:25:10 PM »
Yes it is and they always go wrong so it's a good idea to replace it before it leaves you stranded somewhere. The main problem is that the insulation of the pick-up wires inside the distributor hardens with heat and eventually breaks due to being bent back and forth by the centrifugal advance mechanism.
But the ignition modules rarely go wrong and I wouldn't change it as "preventative maintenance". If you do, then you should also replace the coil as it's more likely to go wrong. In fact I'm not sure if the ignition module is available on its own or if you'll have to buy the complete unit of module, heatsink and coil. Ricambio would probably be your best bet for getting one of these.
« Reply #4 on: October 10, 2012, 08:47:37 PM »
?35  on ebay ..
http://www.ebay.co.uk/itm/FIAT-131-MIRAFIORI-ELECTRONIC-IGNITION-MODULE-2-0-77-85-OE-QUALITY-/290623518155?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43aa82f5cb
« Reply #5 on: October 10, 2012, 11:27:43 PM »
Before you spend some money on parts that are not broken, first check the wiring. I agree with thotos that it's mostly the wiring in the distributor. 99 % of 100 that's the problem.
idahobrava
« Reply #6 on: October 11, 2012, 02:42:15 AM »
I agree with some of the other posts on your ignition module.  I had similar problem with what I thought was a module going bad,  it was the wiring from the coil that had corroded and the wiring connectors were cracked and I was loosing spark and the car would die.  I built new leads and the problem stopped.  I did also find that the distributor pickup from the module was also bad from the insulation coming off the wires,  it was also replaced.  So far so good,  about 5000 miles since the fix and still running strong.  The module is also a very common GM part in the USA and very inexpensive,  I carry a spare in the car just in case it ever fails.  Mike Stinson
« Reply #7 on: October 11, 2012, 10:08:41 AM »
Here's a slightly cheaper one:
http://www.ebay.co.uk/itm/Alfa-Romeo-Lancia-Seat-Fiat-Electronic-Ignition-Module-3625-/280735398320?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415d2239b0
and here's another (cheaper) one that also gives a comprehensive equivalents list:
http://www.ebay.co.uk/itm/NEW-IGNITION-MODULE-FOR-ALFA-ROMEO-SEAT-LANCIA-PEUGEOT-RENAULT-/251097520176?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a76941830
« Reply #8 on: October 11, 2012, 11:42:43 AM »
US $16.20
http://www.autoricambi.us/product/IG3-464/Ignition-Control-Module/
http://www.autoricambi.us/product/IG3-464-A/Ignition-Control-Module---PERFORMANCE-Upgrade/
They rarely fail and replacing one for "preventative maintenance" is wasting money.
