September 13, 2026, 03:32:09 PM
| | |-+  Intermittent wipers?
Author Topic: Intermittent wipers?  (Read 8087 times)
« on: October 19, 2012, 12:52:49 AM »
My wipers are more random than intermittent. They'll run for a second then stop anywhere on the screen, they'll do this continuously on the intermittent switch, but run fine on continuous 1 and 2. They will also stop immediately when turned off, instead of returning to a "park" position at the bottom of the screen. Is the circuitry for controlling the intermittent function part of the wiper motor internal circuitry, or a function of the vehicle circuitry. I'm assuming part of the motor setup.
« Reply #1 on: October 19, 2012, 07:43:20 AM »
It's a switch inside the motor. By 'switch' I mean a fixed contact and one on a long metal strip controlled by a cam wheel. Either the contacts are worn/loose/dirty, the 'strip' contact has broken or one of the wires has come off. Wires are easy to check  as you only need to take off the first cover (just three screws from what I remember). If wire connections haven't broken off then take off the fourth screw (also holds the cable clamp from memory) and you'll find the 'switch' inside. The problem will be obvious and usually quite easy to repair. Even if the contact strip has broken off it can be soldered back on (but won't last forever).
« Reply #2 on: October 19, 2012, 08:02:52 AM »
I don't think it's the wiper motor. I had the same problem some time ago in my Racing. I exchanged the intermitterance relais that's located under the bonnet on the right side, between the firewall and the shock tower. Then the problem was solved.
« Reply #3 on: October 19, 2012, 08:29:36 AM »
Therefore not the intermittent relay but the switch inside the motor  Wink
« Reply #4 on: October 19, 2012, 06:46:33 PM »
yes ,, take it apart and you'll see and full of grease .
« Reply #5 on: October 20, 2012, 03:37:59 AM »
Thanks everyone, it was indeed the internal switch, the "leaf" had corroded and fallen off, fortunately straight onto the grease on the gear, so it stayed put and didn't cause any damage. I pulled another wiper motor apart but it the cover/switch assembly was completely different, I assume it's from a series 1. I scrounged through my pile of bits and found another motor assembly, the cover was what I required, but the wiring was connected to different terminals. I got the soldering iron out, swapped covers and copied the vehicle wiring to the terminations, it now works a treat, properly parked intermittent wipers and they return to the parked position when turned off. It's only taken me 5 years to fix it. Now the drivers side washer nozzle only squirts half as much as the other side, I've cleaned the nozzle to no avail, I think I've crimped the tube when refitting the firewall plastics. I wonder how long that will annoy me before I fix it.
