September 14, 2026, 12:55:28 PM
| | |-+  fiat 131 sport STEERING Column Switch
Author Topic: fiat 131 sport STEERING Column Switch  (Read 9174 times)
adcostas
« on: October 30, 2012, 09:59:20 PM »
Hi has anyone got a steering column switch for sale must have 1x8 pin 1x6 pin and 1x1 pin ,I purchased one but only to fine out it wont work well it does but you turn on the lights and the wiper start or indicate and the lights flash
thanks
Fiat 2L 131 abarth rep
« Reply #1 on: October 31, 2012, 09:41:00 AM »
PM sent.
« Reply #2 on: October 31, 2012, 10:46:44 PM »
It is probably from a US version - you should be able to change the wires in the connector plugs.
adcostas
« Reply #3 on: October 31, 2012, 10:54:50 PM »
Hi miro i tried that but it has 3 more wires then my one and different colours on most of them  ..
somebody must have one
« Reply #4 on: October 31, 2012, 11:55:14 PM »
Just try shorting the wires sticking out of car to see which does what  ( or better see the wiring diagram) and than test the operation of the switch. Than just match the wires . It will take some time but can be done.
M
adcostas
« Reply #5 on: November 01, 2012, 07:00:19 PM »
Hi Miro i tried it today i got the lights working indicators i just have to play around with the wiper wires to get them working properly as on first click it goes fast then second intermittent  but yes almost there
thanks for the advice
costas
