July 30, 2026, 09:39:00 AM
| | |-+  Weber Carb Repair Kits
Author Topic: Weber Carb Repair Kits  (Read 7952 times)
beardy bloke
« on: November 25, 2012, 03:02:50 PM »
I need to find a repair/service kit for my 32ADF 14/250 , my engine is a 1600tc, any suggestions would be very helpful.
« Reply #1 on: November 25, 2012, 04:26:58 PM »
WEBER 32 ADFA/32 ADF CARBURETOR SERVICE KIT
 ebay item no..       290421804229
beardy bloke
« Reply #2 on: November 26, 2012, 07:17:17 PM »
Thanks for that help.I am not that knowledgeable about this things but i have read that the kit should include all the replacement jets etc... this kit does not appear to have all of these ,or do you think this includes everything i need . My carb has a flat spot which i have been told is due to the jets being blocked so i wanted to make sure i replaced these . They also have for sale a rebuilt adf 32 do you think that this would be a better choice long term as when my car was put back on the road the accelerator pump housing was partially rusted through, the one shown has a different arrangement of the position of the pipes going onto the water choke?. The car doesn`t run too bad but i would like it to run a bit better so was also cosidering up grading to a larger single carb do you have any views of what would fit onto the inlet manifold easily?.
« Reply #3 on: November 26, 2012, 07:22:07 PM »
I never known them come with jets  (about ?9 each from webber ) just take it all apart and clean and poke the crud out of all the jets .
