October 24, 2026, 04:11:00 PM
| | |-+  16 valve/engine code questions
Author Topic: 16 valve/engine code questions  (Read 11536 times)
« on: February 09, 2013, 08:47:28 PM »
I'm not up to speed on the 16 valve engine so a question.
Were all 16 valve engines 2 litre or did they do other sizes.
Also does anyone know what engine the engine code 131 b1.000 is
« Reply #1 on: February 09, 2013, 09:13:22 PM »
All 16 V engines for 131 Abarth were 2 litre engines, except for 035 which was a 1400 cc. Lancia 037 used the same head and i believe they also had 1400 cc engines, but i'm not sure.
« Reply #2 on: February 10, 2013, 09:44:24 AM »
FIAT 131
HSN / TSN    4001/739
Motorkennbuchstabe   131 B1.000
gebaut ab   03.1979
gebaut bis   03.1982
Hubraum   1585
Leistung (kW/PS)   72kW / 98PS
Enzo
131 Abarth engine code:
131 AR.000  1995cc 84mm bore, 90mm stroke.
« Reply #3 on: February 10, 2013, 10:32:40 AM »
So that engine code is for an 8 valve engine. Thought so Smiley
« Reply #4 on: February 10, 2013, 01:45:19 PM »
Is b.1000 not the 1600 twin cam ?
« Reply #5 on: February 10, 2013, 03:04:46 PM »
Yes it is, see Enzo's posting: Hubraum (= displacement) 1585 (cc)
« Reply #6 on: February 10, 2013, 03:19:30 PM »
It's the single overhead cam engine.
131Steve
« Reply #7 on: February 11, 2013, 10:38:29 PM »
I found this in an old copy of "Bialbero" from the winter 1988 edition - it was the magazine of the FIAT Twin cam register.
It's posted as a .pdf too incase the .jpg isn't clear enough
Hope it helps  Smiley
* FIAT TC Engine numbers.pdf (119.49 KB - downloaded 766 times.)
Silver 131 Racing 1980 (previously two 131 S2 1600TC Supers, three 131 Sports, one 131 S3 Super 2000TC)
