October 24, 2026, 04:10:47 PM
| | |-+  Window Rubber Seal
Author Topic: Window Rubber Seal  (Read 28621 times)
cypriot
« on: February 24, 2013, 03:42:26 PM »
Hi all,
I wonder if rubber seal of the window marked at the picture at 2 door 131 same with 4 door 131 's which also has similar window there.
I need two new rubber seal for these small windows.
waiting your information.
cheers
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
H?rmann Intake Manifold
Weber 40 IDF Carbs
GC Spec FW
« Reply #1 on: February 24, 2013, 04:01:25 PM »
The four door cars do not have the little triangular window (quarterlight) as the front doors are smaller and they have just the one opening window.
Which seal do you actually need? The whole 'triangle' rubber that fits all the way round the little window?
cypriot
« Reply #2 on: February 24, 2013, 05:14:27 PM »
Hello,
Nope serie 1, 4 doors also have small triangle Windows at the front doors. At least I know Tofas 131 first series have these windows. See link
http://ilan.elookat.com/ilan-tofas-131-araba-muayyar-2700-uasuAAN-1482602.htm
And yes I need the whole 'triangle' rubber that fits all the way round the little window
I can easily find that rubber seal for 4 doors but I should be sure that it is same with 2 doors triangle windows
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
« Reply #3 on: February 24, 2013, 05:24:12 PM »
It's a day of learning for me today it seems  Undecided
But I never claimed to know anything about the Tofas cars  Grin
The Original Fiat Series 1 4-door cars don't have the triangular window.
« Reply #4 on: February 25, 2013, 05:06:51 PM »
Theo,
the Tofas pic it's a fake picture like this!  Grin
Enzo  Wink
cypriot
« Reply #5 on: February 25, 2013, 06:31:15 PM »
Theo,
Enzo  Wink
Lol Enzo
It is not fake
http://www.banaarababul.com/satilik-FIAT-TOFAS-131-SAHIN-Kahramanmaras-1978-5952551.aspx
Google "tofas 131 1978 1979 etc"
You will see
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
« Reply #6 on: February 26, 2013, 08:51:03 AM »
if it exists on Tofas 131,  it will be not a problem to found it from Yagmur!  Wink
http://www.131mirafiori.com/smf/index.php?topic=81.0
Yagmur
« Reply #7 on: February 26, 2013, 04:59:34 PM »
Thanks Enzo....
Yes our cars have triangular windows...so I have rubbers...
cypriot
« Reply #8 on: February 26, 2013, 05:08:51 PM »
Thanks Enzo....
Hello Yağmur,
Are those rubber seals for front triangular windows of tofas 131 same with two door Fiat 131 ?
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
Yagmur
« Reply #9 on: February 26, 2013, 07:14:32 PM »
Hi Ali,
I have no idea about the dimensions.....
cypriot
« Reply #10 on: February 26, 2013, 07:22:42 PM »
Hi Ali,
Hi Yagmur,
I have both side old ones one of them really bad condition but
I can measure one of them tomorrow and let you know dimensions.
Ali
I was calling you this morning regarding parts bur I need to try local tofas Garage first they still have some parts
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
« Reply #11 on: February 26, 2013, 07:43:52 PM »
Theo
When did you take that picture of the pale yellow 131, or is it one you got off the net.
« Reply #12 on: February 26, 2013, 08:56:32 PM »
Off the 'net. It's from Wiki images entitled Fiat_131_early_one_in_England.jpg   Wink
I used to have a metallic Blue 1600 Special 4-door so I suppose I could have used one of the many photos I have of my car but 'picking up' one off the Internet was quicker  Grin
« Reply #13 on: February 26, 2013, 10:14:43 PM »
It's a great picture in a typical UK setting.
Is it an N Reg. If so then it must be one of the first.
In fact I cannot remember seeing a round headlight 131 on anything older then a P reg.
« Reply #14 on: February 26, 2013, 11:01:02 PM »
It does look like an 'N' reg.
Mine was a 'P' (NMH 114P).
