October 23, 2026, 02:33:38 PM
| | |-+  Window Rubber Seal
Author Topic: Window Rubber Seal  (Read 28586 times)
« Reply #15 on: February 27, 2013, 12:10:54 AM »
Looking at this picture, you can see why Simon is such a fan of the S1.
The model towards the end of the S1's (were they the 'S' version) had the Head Rests and 5 Speed Gear Boxes.
Were these on an 'R' and 'S' plates.
Did any left over S1 stock make it on to  'T' plate. I know there are many 'S' plate S2 Cars.
« Reply #16 on: February 27, 2013, 12:43:22 AM »
Mine was a 'P' (NMH 114P).
Actually my arthritis of the brain must have got the better of me ...  Undecided
I've checked as the registration I quoted didn't sound 'right' and mine was an 'R' (NMH114R)  Undecided
PS I still have that Mountney steering wheel on my garage wall. It was first in my 124 Special and then went on to live on Dudley (my silver Sport) for years.  Cheesy It must be nearly 40 years old and it still looks fine. Now both the Mountney steering wheel and Dudley's original Sport wheel are mounted on my garage wall side by side.  Grin
« Last Edit: February 28, 2013, 02:10:06 AM by Thotos » Logged
« Reply #17 on: February 27, 2013, 10:23:29 PM »
What a great picture and the making of memories no doubt.
Where was the picture taken and in what year.
I also note the Townsend Thoresen 'GB' Sticker. Another name from the past.
« Reply #18 on: February 27, 2013, 11:03:39 PM »
Outside Koblenz in Germany in 1981. See the original post with that photo at http://www.131mirafiori.com/smf/index.php?topic=94.msg543#msg543
Wow! Your eyesight must be good  Shocked I better get my eyes checked again ...  Undecided
« Reply #19 on: March 01, 2013, 12:50:22 AM »
Yes our cars have triangular windows...so I have rubbers...
But this one doesn't  Undecided
Yagmur
« Reply #20 on: March 01, 2013, 06:09:16 AM »
this is 1984 model, old models have triangular windows, up to 1982....
cypriot
« Reply #21 on: March 03, 2013, 02:54:42 PM »
Hello,
Yagmur here is the dimensions of front door triangular windows of my 2 door 131
505mm x 365mm x 335mm
99% early tofas 131 has same window rubber seals for these triangular windows.
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
H?rmann Intake Manifold
Weber 40 IDF Carbs
GC Spec FW
Yagmur
« Reply #22 on: March 03, 2013, 06:18:42 PM »
I am going to check the dimensions...
cypriot
« Reply #23 on: March 03, 2013, 06:27:56 PM »
I took off rubber seal and get this measurements.
Sorry for using Turkish guys
Yagmur lastiği ?ıkarıp ?l??leri direk olarak camdan aldım
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
cypriot
« Reply #24 on: March 09, 2013, 04:54:32 PM »
Hello,
This morning I visited scrap and found several series 1 tofas (sahin) with triangular front window. I took measurements and bottom length of triangle window is about 10 - 15mm longer SHORTER than 2 door fiat 131 triangular window.
Yagmur, direkli 131 sahin ?n kelebek camı bulup karsılastırdım. Ne yazık ?l?? tutmuyor. 131 sahin kelebek camı alt kısımda 10-15mm daha kısa
Bu arada email atmıştım, banka hesap numarasını hen?z bana bildirmedin.
Ali
« Last Edit: March 11, 2013, 09:38:30 AM by cypriot » Logged
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
Yagmur
« Reply #25 on: March 11, 2013, 09:17:14 AM »
Sevgili Ali,
Ben de ?l?? aynı, maalesf tutmadı..ama bir yerden haber bekliyorum,?ok temiz ikinci el i?in.
PTT fiyatı alamadık hen?z, alınca hesap no bildiririm.
selamlar
Yagmur
cypriot
« Reply #26 on: March 11, 2013, 09:39:35 AM »
Sevgili Ali,
selamlar
Yagmur
Selamlar Yağmur,
PTT ?creti ve hesap no ile ilgili senden haber bekliyorum.
Saygılar
Ali
WR Ltd Edition
Mods:
Gr.4 Tarmac BodyKit
124 Abarth cyl head
High Comp. Pistons
4-1 Header
Weber 40 IDF Carbs
GC Spec FW
