October 23, 2026, 06:33:48 PM
| | |-+  Grill removal on S2 Mirafiori
Author Topic: Grill removal on S2 Mirafiori  (Read 7810 times)
marco
« on: March 03, 2013, 07:26:32 PM »
How do I remove the grill on my 131 for repairs and cleaning?
2008 MITSUBISHI PAJERO
2007 MITSUBISHI OUTLANDER
1980 FIAT 131 SUPERSTRADA
marco
« Reply #1 on: March 04, 2013, 11:01:02 AM »
I suppose I'm on my own on this one? Sad
« Reply #2 on: March 04, 2013, 11:13:26 AM »
Hi Marco,
I wil help you  Wink
Look at the front of the grille. You will notice some screws. These are easy to remove. The problem is the fixing around the headlights. It's done with clips and with a tight fit.
I removed the grille in this way: i took off the bonnet en stuck a screwdriver between the grille and the upper chassis bar. I made sure not to damage the bar by winding a piece of cloth around the screwdriver.
Be very carefull and use limited force, for the components can easely break.
Good luck,
Mike
marco
« Reply #3 on: March 05, 2013, 12:41:19 PM »
 :)Thank you will try this afternoon cheers
