September 14, 2026, 01:35:39 PM
| | |-+  Search original Carburettor Racing 2.0 TC
Author Topic: Search original Carburettor Racing 2.0 TC  (Read 8555 times)
rosi
131 Rally
« on: May 06, 2013, 09:36:04 AM »
Hello, i need your Help.
Urgently im searching one original Carburettor (register carburettor) from the fiat 131 2.0 TC Racing.
Completly with aspiration hole and accelerator cable/mechanism. The Airfilterbox is available.
Anybody can help me? Sending to Switzerland.
The swiss car authority have d'ont accept the double carbs in my car. I must they change it.
Regards from Zurich
rosi
« Reply #1 on: May 24, 2013, 12:24:29 AM »
Have a set for you !
« Reply #2 on: May 24, 2013, 02:43:26 AM »
If you must go back to a 2 barrel, track down one of these:
http://www.ebay.com.au/itm/Ford-XE-XF-Weber-Carby-/121112739766?pt=AU_Car_Parts_Accessories&hash=item1c32e1bfb6
34ADM weber, as used on many 6 cylinder Fords in Australia. 34mm throttle plates and 27/29mm venturies, as opposed to the 34ADF 24/26mm venturies. If you mix & match the throttle section and venturi body no-one will be any the wiser unless they dismantle the carb to measure the venturi sizes.
CkRacing
« Reply #3 on: May 24, 2013, 06:36:35 AM »
Electric choke?
« Reply #4 on: May 24, 2013, 08:27:55 AM »
Electric choke?
Swap the top and you have original water choke.
CkRacing
« Reply #5 on: May 24, 2013, 09:22:35 AM »
The electric choke sounds good
I have a spare carb any idea where i can get that choke part?
rosi
131 Rally
« Reply #6 on: June 06, 2013, 12:10:28 PM »
BOUGHT
« Reply #7 on: June 08, 2013, 12:39:55 AM »
Hi
As Rossi bought it from someone else the carbs and manifiold on pictures below are still available
