July 28, 2026, 07:11:46 AM
| | |-+  Fuel Flow Rates
Author Topic: Fuel Flow Rates  (Read 17609 times)
« Reply #15 on: June 19, 2013, 07:09:47 PM »
Once up to temp about five miles of fast and slow work should show a problem, like a garage road test
beardy bloke
« Reply #16 on: June 20, 2013, 05:58:44 PM »
I will let you know how it goes , I am going to try a long run at the weekend although I have other issues with dodgy TVR electrics which may stop me. I have a lot of trouble getting up to temp only really goes up under heavy load or stuck in traffic , do these engines always run cool ?. I also think that I probably have crap in the tank as when I took fuel filter off it was full of rust , I have replaced so will keep an eye on it. I suspect my problems sound similar to the other thread relating to the racing not running right . Is there an easy clean method as my tank can only come out through the car or by removing the rear window.
« Reply #17 on: June 20, 2013, 09:37:13 PM »
The needle should sit around the centre of the gauge when up to temp, if it doesn't get up to temp your thermostat is suspect.
