October 25, 2026, 07:06:51 PM
| | |-+  Crank case pressure ..
Author Topic: Crank case pressure ..  (Read 9354 times)
« on: July 27, 2013, 09:36:32 PM »
Anyone used any of those oil additives that seal bores  Undecided
 900 miles flat out  in 10 hours has been a bit  punishing on the ole beast , blowing a bit a oil out the did stick rubber ,
with a new rubber bit and breather is cleared out !
  Amtech was one , as slick 50 is under ivestigasion and most forum poo these claims ?
« Reply #1 on: July 28, 2013, 12:07:34 AM »
Rings seal bores, oil additives unseal your wallet.
« Reply #2 on: July 28, 2013, 07:38:00 PM »
Got to be worth a try in cost terms compared to an engine rebuild Wink
« Reply #3 on: July 28, 2013, 09:30:28 PM »
Ill try  15w 40  oil first i now i should have put it in first instead of 10w 40  anday be an extra bresth on the filler ?
« Reply #4 on: July 29, 2013, 10:45:47 AM »
Never use 10W 40 oil in a 131 engine Cry ! It's to tin and is not good for a 131 engine.
« Reply #5 on: July 31, 2013, 11:54:22 AM »
I used one of those additives years ago on a vauxhall chevette and it was a complete waste of money and had no effect what so ever.
