October 24, 2026, 01:26:58 AM
| | |-+  Pilot bearing
Author Topic: Pilot bearing  (Read 11119 times)
longhamrob
« on: August 07, 2013, 12:24:40 PM »
I intend to replace this tomorrow on my 131r.  I have a new bearing purchased off ebay but am concerned it is the correct one.  Has anybody got an engine out & conveniently placed where at least the diameter & internal diameter can be measured?  Alternatively can anybody confirm the correct dimensions before I risk a massive waste of time.....
« Reply #1 on: August 07, 2013, 02:58:17 PM »
Rob, Do you mean the bearing in the end of the crankshaft for the geabox shaft to sit in ?
longhamrob
« Reply #2 on: August 07, 2013, 03:10:10 PM »
Hi David.  Yes that one.
« Reply #3 on: August 07, 2013, 07:25:39 PM »
I have an engine out of the car but its up my old man's place so it won't be until friday hopefully that I will get up there is that any good ?  can only measure it with a tape measure as I've lost my micrometer but that should be fine.
« Reply #4 on: August 07, 2013, 10:01:19 PM »
I've got a new bearing in it's packaging I haven't installed yet. I can measure it, but it won't be until this afternoon.
longhamrob
« Reply #5 on: August 08, 2013, 06:06:30 AM »
Hi Mick.
I appreciate the time difference but were you able to measure as I am starting job in a few hours. Thanks.
« Reply #6 on: August 08, 2013, 10:37:00 AM »
Forgot all about it, I'll go out and do it now.
« Reply #7 on: August 08, 2013, 11:21:31 AM »
15mm (ID) x35mm (OD) x14mm (deep)
http://www.skf.com/skf/productcatalogue/jsp/viewers/productTableViewer.jsp?lang=en&tableName=1_1_1&presentationType=3&action=&perfid=&newlink=&designationField=&searchway=1&c.2_min=15&c.2_max=16&c.4_min=35&c.4_max=36&c.7_min=14&c.7_max=15&c.32_min=&c.32_max=&c.41_min=&c.41_max=&imperial=false&impSearchValues=false
longhamrob
« Reply #8 on: August 08, 2013, 12:32:22 PM »
Thank you for that. I did have the wrong bearing but was able to source locally. Much appreciated Mick.
