October 24, 2026, 06:11:11 PM
| | |-+  Brake caliper banjo bolts..........
Author Topic: Brake caliper banjo bolts..........  (Read 9130 times)
donk r8
Chris Paull
« on: November 11, 2013, 06:13:21 PM »
 Hi Guys, got some reconditioned calipers for the 131 but they are a newer version and the banjo's need to be shorter, it has 84 stamped on the caliper so I assume Uno ones would be the right ones?? question is where to get them from, any ideas... Roll Eyes found some on fleabay but does anyone know the exact size......................thanks.......... Smiley
1600 Supermirafiori    Fiat Barchetta  Fiat Ducato 2.8 Motorhome    Rover SD1 4.0 V8
« Reply #1 on: November 11, 2013, 07:05:50 PM »
mine dont have banjo's  Wink or a youkali  Grin
donk r8
Chris Paull
« Reply #2 on: November 11, 2013, 07:53:33 PM »
    Thanks, really helpful.................. Grin Grin
donk r8
Chris Paull
« Reply #3 on: November 12, 2013, 11:02:00 AM »
 Found the right ones....................... Cool
http://www.ebay.co.uk/itm/131002863690?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
strada
« Reply #4 on: November 12, 2013, 07:46:11 PM »
the later calipers have the inlet at an angle rather than vertical, THEY DO NOT USE BANJO BOLTS & THE THREAD IS METRIC, to fit these you need later hoses which screw straight in, also fitted to strada mk2, you may have to change the ends of the metal pipes to metric too depending on what master cylinder is fitted which could be either on a mk2 131.
i also have some orf the other parts you have been looking for on a previos thread but they are from mk3,  pm if any good to you,  chris
donk r8
Chris Paull
« Reply #5 on: November 13, 2013, 05:22:27 PM »
  Hi Chris, thanks for that!! I found out last night while putting the brakes back together as I found a set of later brake lines in the workshop and trawling through the grey matter I remembered how they used to be!! I have sent you a pm regarding the other things........................thanks, Chris
« Reply #6 on: November 15, 2013, 06:34:29 AM »
Both threads are metric, one is 1mm pitch, the other 1.25mm I believe.
