September 13, 2026, 03:32:09 PM
| | |-+  Replacing heater box?
Author Topic: Replacing heater box?  (Read 11937 times)
« on: January 30, 2014, 08:39:52 PM »
My latest 131 had OEM aircon, the engine bay bits are long gone, but A/C heater box is still installed. The heater doesn't work particularly well, I back flushed it recently when I changed the head, it flows fine and the control valve works as it should. The problem is it doesn't supply much heat, and only when the fan is running. I've got a good heater box out of my other non A/C car, and the heater worked very well, I'd like to swap them over. Is there a technique to remove and replace without removing all the dash? Taking the one out of the non A/C car was painful, and I imagine the extra complexity in the A/C car would be worse.
Henk
« Reply #1 on: January 30, 2014, 08:59:15 PM »
i am not sure but the AC box has a totally different lay out, I think, and it would not suprise me if the heatercore is different as well...
The AC version  was made by autoclima I think.
If you decide to change the complete box, I would like to buy your ac box, I have all the other parts to fit AC to mine only the hvac box is missing.
I then have all the non AC parts for you as well,  casing (new from Yagmur), blower (different to ac,) flaps, valve, panel etc
Henk
Fiat Mirafiori 1.6 A1.00
MB W114 280 C
Honda CB750 1972
BMW E30 318 Touring
Mini 2006 Cooper S
« Reply #2 on: January 30, 2014, 09:12:07 PM »
As far as I can remember the dash has to come out to remove the heater box assembly. I think you can get the matrix out without removing anything else. So if you can find a replacement matrix you could just fit that.
« Reply #3 on: January 30, 2014, 11:18:46 PM »
You have to remove the dash not difficult lad!
« Reply #4 on: February 01, 2014, 06:59:13 AM »
Where abouts are you Henk. I'm in Tasmania, freight would be painful. Then again, a fellow 131 tragic bought a left rear guard from me and had me air freight it to Ireland, and then didn't use it because he found new bits.
ZFA16V
« Reply #5 on: February 01, 2014, 10:28:19 AM »
Hello neighbour,
Will Agree with sid131...Dash out.
Removed the dash from my series 3 track 131,and yes it looks like thats
the only way to do it.
« Last Edit: February 01, 2014, 10:47:24 AM by ZFA16V » Logged
Henk
« Reply #6 on: February 01, 2014, 10:33:47 AM »
I am in the Netherlands but would be willing to pay for n AC housing and controlpanel
If you decide to take it out and replace it with a non AC casing I would like to have a quote for shipping it to me.
cheers
Henk
Henk
MB W114 280 C
Honda CB750 1972
BMW E30 318 Touring
Mini 2006 Cooper S
« Reply #7 on: February 09, 2014, 06:51:42 AM »
Started the removal process yesterday, got the A/C box out, and after giving the non A/C box a going over this morning it's now fitted in the car. And of course the wiring is different, but I've got the harness from the other car, so I'll source the section I need from that and splice it in.
« Reply #8 on: February 09, 2014, 06:59:23 AM »
A/C box is much harder to remove than a standard heater box, access to fasteners is obscured by vacuum actuators etc.
Henk
« Reply #9 on: February 16, 2014, 08:13:17 AM »
making progress, I see
would you sill consider selling the AC box to me?
henk
Henk
MB W114 280 C
Honda CB750 1972
BMW E30 318 Touring
Mini 2006 Cooper S
