September 13, 2026, 03:01:42 PM
| | |-+  Adjustable Panhard
Author Topic: Adjustable Panhard  (Read 9613 times)
finnie
« on: February 12, 2014, 09:57:07 PM »
Hi all
I want to make my panhard rod adjustable and been trying to find a bolt with LH and RH threads but cant find one anywhere -
What would you call it ? And where to get it from ?
I`m trying to avoid welding 2 bolts together .
Finn
« Reply #1 on: February 12, 2014, 10:09:22 PM »
Hi Finn,
What you need is something like this part in my picture. Look at the left. I don't know the english word for it, but here in holland we call it kopstang. In Germany it's called uniball.
You'd have to cut of the head parts of the Panhard and weld in two large nuts in the rod. One left and one right.
« Reply #2 on: February 12, 2014, 10:52:58 PM »
Hi Finn you could go the rose joint way with one on each end but not great really Wink
I made an adjustable panhard rod for my 131 racing as i was fitting lowering springs & i need to be able to adjust without taking on & off, you will have to get a left hand right hand fine thread turnbuckle machined up & cut your rod & weld in situ  Wink
finnie
« Reply #3 on: February 22, 2014, 05:19:37 PM »
Thanks Sid - just finished my panhard like yours  Wink
« Reply #4 on: February 23, 2014, 08:48:56 PM »
This is watt you should be trying for if anything
https://www.google.co.uk/search?q=watts+linkage&safe=off&client=firefox-a&hs=t2M&rls=org.mozilla:en-US:official&channel=sb&tbm=isch&tbo=u&source=univ&sa=X&ei=wF8KU9P9N7Dn7AbTtoAw&ved=0CEQQsAQ&biw=1366&bih=639
« Last Edit: February 23, 2014, 08:57:07 PM by jasonh131 » Logged
finnie
« Reply #5 on: February 23, 2014, 11:19:29 PM »
To much engineering for my old banger  Grin jason
ZFA16V
« Reply #6 on: March 02, 2014, 11:13:28 AM »
I know that you have done the mod already...
But i purchased a rose joint from the UK...cut the end of the rod(body side)
and welded the rose joint on with a lock nut.
It also works well...you have to drop it on one side to adjust,but you
only do it the one time.
Will post a pic soon.
