September 13, 2026, 03:01:31 PM
| | |-+  Cross member
Author Topic: Cross member  (Read 13888 times)
finnie
« on: March 09, 2014, 10:09:31 PM »
Recently bought some very nice parts from Marko on here but only found out this weekend that my front cross member
is different to anything else that I've seen and also my gearbox mount is different .My car is a series 3 131 .
Has this car been messed about with -it`s a import- or are these 2 items different?
« Reply #1 on: March 09, 2014, 10:34:05 PM »
not sure about the gearbox mount, but the cross-member on a series 3 is definitely different to
the rest of the cross-members ,it's due to the power steering set up on the later models.. its mounting holes for the steering rack are in a slightly different position and on the series 3 the steering column from the wheel to the rack is shorter & thicker than the rest.
I was a while searching for this type of rack for myself before a fellow member on here sorted me out with one
.. Smiley
finnie
« Reply #2 on: March 09, 2014, 10:46:48 PM »
Ok thanks .
So is the steering rack different  as well as the column ? if then it`s a lot of work to change over  Sad
« Reply #3 on: March 10, 2014, 02:36:14 AM »
Series 3 gearbox mounts are also quite different. There's a thread on this forum about them as Kevin had trouble sourcing a new mount for his Series 3 Super.
« Reply #4 on: March 10, 2014, 06:44:42 PM »
To go from series 2 sport to series 3 with power steering for sure you have to  change
cross-member, steering rack & column..
Last time I did it with all the bits ready to go took me a day ..
As far as I know all series 3  131's have power steering .. but not 100% on that ..
but any I have ever seen have..
« Reply #5 on: March 10, 2014, 06:48:16 PM »
Only the series 3 Supermirafiori had power steering as standard. I fitted it to my CL that I turned into a series 2/3 Supermirafiori hybrid.
I have some power steering parts but haven't decided yet if I should convert my Supermirafiori or Panorama.
finnie
« Reply #6 on: March 10, 2014, 08:19:55 PM »
My series 3 don`t have power steering
131 Lover
Fiat power No mercy !!!
« Reply #7 on: March 11, 2014, 05:27:14 AM »
I don't think Skandinavia got any with power steering, have never seen any!
well, we are quite well built so no need for power steering anyway!
Alf
« Last Edit: March 11, 2014, 05:44:30 AM by 131 Lover » Logged
These are my Fiats
2x 131 2-door 1600cl -81
finnie
« Reply #8 on: March 11, 2014, 09:02:44 AM »
Alf
Vikings don`t need power steering  Cheesy
« Reply #9 on: March 11, 2014, 06:36:57 PM »
Alf
 Cheesy
« Reply #10 on: March 11, 2014, 08:32:53 PM »
I will probably fit electric power steering instead of hydraulic in my 131. if someone needs it then you can use the one from Fiat seicento. it uses separate ecu and has its own wiring harness so quite simple installation.
« Reply #11 on: March 11, 2014, 09:14:28 PM »
Interesting possibility there. Is it a straightforward? Do you fit the whole steering column?
