October 23, 2026, 02:33:38 PM
| | |-+  Rear disc brake
Author Topic: Rear disc brake  (Read 23823 times)
« Reply #15 on: May 20, 2014, 06:31:08 AM »
Has the 132 & Argenta limited slip diff or are they only one wheelers?
The early 132 had what we call a banjo diff centre, the whole centre pulled out from the front of the axle housing, they were the smaller 8 bolt CW&P, the later ones were salisbury, the centre was assembled in the axle housing via the rear plate, some were the small CW&P, and some were the larger 10 bolt CW&P. LSD was available on the later type, but very rare in OZ. The larger CW&P was Borg Warner I'm lead to believe, Fiat had 3 ratios, 10/41, 11/41 and 12/41, different ratios from other cars should be available also.
« Reply #16 on: May 20, 2014, 06:43:50 AM »
131racing
« Reply #17 on: May 25, 2014, 02:06:49 PM »
What position of the caliper is the best .infront of disc of rear of disc?what discs grooved and drilled suggest ?
POQ 131
« Reply #18 on: May 27, 2014, 12:24:49 AM »
Now that you will be using a 132 rear axle set up, the calliper position has been decided for you by the 132 mount. IMHO you will not need to drill the discs.
 O.
O.
« Reply #19 on: May 27, 2014, 08:03:58 AM »
Maby not but drilled discs do look cool imo Wink
