September 15, 2026, 06:06:17 PM
| | |-+  Dutton Phaeton 131
Author Topic: Dutton Phaeton 131  (Read 9067 times)
rocky_679
« on: July 12, 2015, 11:30:24 AM »
have bought a Dutton Phaeton kit car it has fitted a 131 super mirafiori 2 ltr engine mated to a fiat 124 gearbox, the donut on the propshaft which the 124 has is catching the chassis member so does any one know where i can find a bell housing for a 131 and a single piece propshaft  Huh the 132 engine im runing twin 40s vertical
* 10649986_10153979811515744_3790863296081798775_n.jpg (134.89 KB, 960x720 - viewed 1142 times.)
« Reply #1 on: July 12, 2015, 06:01:17 PM »
Nice engine any way, cam vernier mean  special cams  ?
  i take this was not a sorted kit car !
 most off the props are the same have a donut , how much room is there under there , take a pic .
  could the engine be moved over or the box section cut out and moved to side ,seen that done before
 on it fitint of retro firt engines .
 some one else may know about a prop having no dounts just UJs
« Reply #2 on: July 12, 2015, 06:10:19 PM »
Does it have a centre bearing? If so check the bracket is on the right way round. From memory if irs the wrong way round it will pull the shaft slightly off centre.
rocky_679
« Reply #3 on: July 12, 2015, 08:56:08 PM »
yes it has a donut and a 2 piece prop
rocky_679
« Reply #4 on: July 12, 2015, 09:22:14 PM »
meant to say  definitely sorted  Grin just the prop has started to foul as the modification as the mounting has got old an worn
« Reply #5 on: July 13, 2015, 05:54:28 PM »
 If that is all it is   !! just renew all the worn mounts  .. Huh Roll Eyes Roll Eyes Roll Eyes
rocky_679
« Reply #6 on: July 15, 2015, 09:16:23 AM »
the mounts where custom made  Cry
