October 23, 2026, 01:37:02 PM
| | |-+  Rear calipers pipe
Author Topic: Rear calipers pipe  (Read 15817 times)
131racing
« on: July 21, 2015, 07:26:54 PM »
hi is it bad that i mount the copper pipe directly to the rear caliper instead a rubber one???
« Reply #1 on: July 21, 2015, 07:37:51 PM »
If there is any movement in the system and you use a solid pipe  then the pipe could fracture leading to brake failure.
« Reply #2 on: July 22, 2015, 08:09:05 AM »
You need a flexible hose to allow caliper movement.
Che
« Reply #3 on: July 22, 2015, 09:03:02 AM »
Seriously dangerous without the flexible pipe
'Salesmen are today's great communicators. They are out there pushing cars, real estate, advertising.
 That is where the real morality is played out in society today.'
 Jeff Koons. b.1955
POQ 131
« Reply #4 on: August 17, 2015, 08:19:44 AM »
Copper pipe  Shocked. You are freaking me out.
Brake lines must be steel. Some steel lines have a copper wash to protect them. Is that what you have ?
O.
O.
vode131
« Reply #5 on: August 17, 2015, 08:57:54 AM »
What is wrong with copperpipes?
Offcourse you need hoses to connect them to calipers.
« Reply #6 on: August 17, 2015, 04:12:37 PM »
The copper ones are usually a copper nickel mix. Steel rusts which is why most replacement brake pipe is copper based.
POQ 131
« Reply #7 on: August 23, 2015, 10:54:47 AM »
Yeah, well I do live down under & here the law says no copper pipe.
Apparently it has no where near the pressure rating as steel & will not pass a roadworthy inspection for registration.
The steel pipes here are zinc coated & I have seen copper plated ones as well.
A crack or a rub on the rubber or  braided hose puts you out of roadworthy as well.
A power assisted brake hydraulic system can attain 1500 psi.
Lets be safe eh ?
O.
O.
« Reply #8 on: August 23, 2015, 11:09:51 AM »
The copper ones must be legal over here as I've had several cars with them fitted that have passed the UK mot test.
POQ 131
« Reply #9 on: August 23, 2015, 11:54:31 AM »
Those copper/nickel ones you mentioned are very likely good.
 But I would not use soft pure copper.
O.
O.
« Reply #10 on: August 25, 2015, 07:50:05 AM »
When I was in Canberra I put a booster on a non boosted car, the local brake specialist made up the lines for me out of copper.
