October 24, 2026, 01:06:29 PM
| | |-+  Headbolts torque
Author Topic: Headbolts torque  (Read 9636 times)
supermirafiori
« on: December 27, 2015, 11:16:13 PM »
Hi
I have the 1600cc twincam engine (131.c3000). Does anyone know the proper torque to tight the headbolts from the cylinder head. Also can someone describe the  stages (steps) to tight the cylinder head.
« Reply #1 on: December 28, 2015, 10:38:04 AM »
from the archive
http://archive.mirafiori.com/show.php?fid=2&msg=125578
« Reply #2 on: December 28, 2015, 10:53:01 AM »
  Head torque;  but engine looks to be older, Hm  old engine are torqued to Spec.    later engines use stretch bolts which are torqued then turned through an angle.  We decided to go for the older Torque to Spec. the bolts look like normal bolts not wasted like some stretch bolts.
supermirafiori
« Reply #3 on: December 28, 2015, 10:44:35 PM »
So the bolts does not need to be replaced.
According to fiat i can apply the torque "directly"i dont have tighten stages?
« Reply #4 on: January 01, 2016, 08:33:26 AM »
20, 40, 60ft/lb, from the inside bolts out. Make sure you run a tap through the block holes, clean the bolt threads, then lube threads and washers.
