October 24, 2026, 03:08:57 PM
| | |-+  Dellorto 45s fuel return
Author Topic: Dellorto 45s fuel return  (Read 7014 times)
131racing
« on: June 16, 2016, 05:44:25 PM »
Hi i have dellorto dhla 45 s on fiat 131 2000cc engine . Can i use the standard petrol pipe and manual fuel pump ? And the return pipe can be made or no?
« Reply #1 on: June 16, 2016, 11:49:08 PM »
Keep the pipes, change the pump.
Small Facet square one is quiet enough, mine is rubber mounted in the boot.
Wire it into an ignition feed so you don't  accidently  level it on as I did once.
Hidden  off switch for anti theft as well.
Roger...
