September 21, 2026, 03:49:50 PM
| |-+  Down to Business (Moderator: Admin)
| | |-+  131 parts
Pages: 1 ... 15 16 [17] 18 19 ... 45 Go Down Print
Author Topic: 131 parts  (Read 1247575 times)
« Reply #240 on: April 05, 2010, 02:17:24 AM »
Yagmur now has a small stock of the rear parcel shelf reproduced in plastic which if you flock it would be better than original, price only ?25
I want one if you have and do you also have a front parcel shelf that goes in the right side under the dash board? I also need a set of lock barrels (door and boot) for a mkI and  what is the cost for shipping  to Greece? Thank you.
« Last Edit: April 05, 2010, 02:21:02 AM by stathe174 » Logged
Yagmur
« Reply #241 on: April 05, 2010, 05:45:51 AM »
pm me please,rainspeed@gmail.com
I have all.
« Reply #242 on: April 05, 2010, 04:07:09 PM »
Pm sent. Thank you.
« Reply #243 on: April 06, 2010, 08:35:46 PM »
Hi Yagmur,
As you know I am currently working on my rear suspension trying t install an original abarth setup.
We have come across a problem of parts .
The rear turrets  need to be modified to accommodate different springs the Abarth suspension requires.
This in turn requires top mounts  installed from underneath and not as in standard rear - from top.
( the springs will be supported  not on a lower turret spring support ( which must be cut out bot on the top shock mount )
See problem definition on picture "the problem" and "the problem 1"
I therefore need the part that goes on top of front shock and bolts to the body front underneath the turret.
See pictures -  type 1
I have a set of two but the ones installed on the car need replacing and I want to used them for the front .
Do you have such parts ( with cup shaped washer that goes under the top nut) ?
On the forum I have seen you have another type (call it type 2) which consists of  tow elements : one that goes underneath the turret and one that goes on top of the turret - see picture:  type 2 assembly .
These could also be used ( I think ) provided he neck of type 2 will fit onto the top turret opening of 70 mm  and the bolt opening on top is large enough to accommodate a nut and a wrench I must use to bolt the shock.
Actually these may be even better , provided :
1/ the distance between the bolts is 90 mm and not 95 as in type 1
2 / the largest diameter of the bottom part  is smaller than 130mm .
Could you advise ASAP !
« Reply #244 on: April 06, 2010, 08:40:47 PM »
Pictures 1 &2
« Last Edit: April 06, 2010, 10:35:09 PM by miro-1980 » Logged
« Reply #245 on: April 06, 2010, 09:35:44 PM »
here are some pics of more of Yagmurs parts, you will know what they are & if you need any info pm or email Yagmur for prices etc.
« Reply #246 on: April 06, 2010, 09:40:04 PM »
more
« Reply #247 on: April 06, 2010, 09:41:30 PM »
parcel shelf & centre consul
« Reply #248 on: April 06, 2010, 09:43:03 PM »
again consul & door & pillar trims
« Reply #249 on: April 06, 2010, 09:44:49 PM »
trim
« Reply #250 on: April 06, 2010, 09:46:37 PM »
roof cloth & under arch plastic
« Reply #251 on: April 06, 2010, 09:48:08 PM »
take a close look lots of parts
« Reply #252 on: April 06, 2010, 09:50:15 PM »
more & door skins
« Reply #253 on: April 06, 2010, 09:52:25 PM »
panel for the rear crossrail same as fiat 131 sport
« Last Edit: April 06, 2010, 09:53:59 PM by sid131 » Logged
« Reply #254 on: April 06, 2010, 09:54:44 PM »
last one
Pages: 1 ... 15 16 [17] 18 19 ... 45 Go Up Print
